1986 Comanche 2.8 to 3.4 carbed
  • Comanche 2.8
    comanche 2.8
    • Nov 2009
    • 1
    Hi All,
    I am wanting to swap in a 3.4 in place of the carbed 2.8 in a Comanche.
    I know I will need to remove the weight off of the 2.8 flex plate, but why not use the 3.4 flex plate?
    My main question though is, will the 2.8 manifold fit on the 3.4?
    Also will the 2.8 distributor fit the 3.4?
    Thanks
    • 9191
    Good question. I would think you should be able to retain the 3.4 flex plate no problem.
    Yes and yes.
    Welcome!
    • neo71665
      its this big
      • Oct 2005
      • 361
      Not sure on the jeeps but there is a reason why you're not supposed to be able to use the f-body flywheel or flex plate on s-series but for the life of me I can't remember the exact reason.
      87 3.4 4x4 blazer
