Trunk button
  • radray64
    • May 2004
    • 1
    Trunk button
    [b]I recently accuired a trunk button that mounts in the glove boxof my 93 gp, My problem is that the car didn't come with that already mounted, So I have no idea if I can get this to work, the trunk lock looks like it has the wiring and stuff mounted, Not sure where to start from here... I hope someone has tackled this project and has some info. thanks
    RAD
    93 GP
  • dykz34
    • Jan 2004
    • 793
    I believe that it is merely a ground. When you ground the solenoid, it should pop. Therefore, if you run a single wire from the solenoid to the switch it should work.
