What is the proper way for tire rotation,left rear to left front and right rear to right front.
tire rotation
Tags: None
unless you have directional tread, at a minimum you need to swap the tires from left to right. swapping them from front to rear is a theory that i don't necessarily subscribe to.
correct way according to my gm training is, unless directional tires; rear to fronts, fronts cross. Ex: left front to right rear, right front to left rear. but i personally just go front to rear, due to not liking the general rotation of the tires being switched which can cause shifted/separating belts in the tires.[SIGPIC]
12.268@117... 11's to come!
This has been a well argumented debate even within GM for many years with engineers and experts.
Both sides with Valid points.
"Correct" procedure is doing via instructions of owners manual or service manual.
Some GM manuals state cross, some dont, some even seem to change from year to year lol.
Many are against changing the directional rotation of a tire wonce it has been in service. (Left sides on Right sides etc)
To make everyone happy (well except the customers paying or Lube/Tire grunts);
Rear Tires to front, Front tires Cross to Rear, however, you would need to remove tire from rim when crossing to keep the same directional rotation.
All for .2h lols.As of April 2
Engine: 2006 SV6 3500 LX9
Trans: 2002 Getrag F23 5speed
Injectors: #36 GTPs
TB: 65mm TCE
Maf: 1999 3400 Montana.
Beverages: Ice Cold CANADIAN.
A few others have said the same as I was thinking...Originally posted by robertisaar View Postunless you have directional tread, at a minimum you need to swap the tires from left to right. swapping them from front to rear is a theory that i don't necessarily subscribe to.
Most tires of a performance type you buy today ARE directional, so your telling me that you won't rotate your tires period if they are directional?
Not the best way to prevent quicker wear on the front tires if you ask me.
if they are directional and you want to rotate them, obviously move them from front to rear and rear to front, but you would NOT be able to move them from left to right without adverse effects.Originally posted by 3400-95-Modified View PostA few others have said the same as I was thinking...
best way to rotate IMO is buy your tires from an authorized tire dealer, get their lifetime rotate(i work at a Goodyear and we throw that in for free with 4 new tires) and have them do it. that way, it's recorded and on time, that way if you ever have an issue and need to say, warranty a tire, you have proof that they were rotated correctly and on time
Cammed 3400 --> 224whp 210wtq
Cammed 3500 --> ???
1 of 5 3500 J-Bodies
Wow all you smart people with so many valid points but not one of you mentioned the one thing that is most overlooked is WHEN. most cars and suv manufacturers say 12,000 km but the manuals in the cars are right when you buy the car new with the sticker in the door being correctly suited to the tire. I cant remember who said ask the tire shop is probalbly the best bet i think cause of new crazy tires with ratings far different than the stock tires. I also think the front to back is really smart. ive seen many people not rotate an have to buy 2 new tires instead of getting that much more life out of the four.
oh just saw your post it was redbird. did you get your tires from goodyear?
Tire Placard does not state how to rotate tires.As of April 2
Injectors: #36 GTPs
TB: 65mm TCE
This makes a lot of sense to me.Originally posted by MidnightriderZ24 View Postcorrect way according to my gm training is, unless directional tires; rear to fronts, fronts cross. Ex: left front to right rear, right front to left rear. but i personally just go front to rear, due to not liking the general rotation of the tires being switched which can cause shifted/separating belts in the tires.-60v6's 2nd Jon M.
