3.4 dohc
  • tim kidd
    • Nov 2026
    3.4 dohc
    could this motor be easily installed in a s-10?
    i'm sure it could be, but not easily.
      There is probably plenty of room, but you would have to flip the intake around, cut out the portion of the timing chain cover that the P/S pump secures to, fabricate motor mounts and exhaust (unless you used 2 front exhaust manifolds), and then comes wiring. It would be a neat swap though
      • geoffinbc
        Iron Head Enthusiast
        • 5831
        Put a 3.6L DOHC motor in. It is already set up for RWD.
