Window Motor?
  • Anonymous
    Window Motor?
    Well my driver's side window hasn't worked for a month now, and my parents got me a new motor for HS graduation. (I graduated #16 of 342, with a GPA of 4.13, act of 31, and I forgot my SAT)
    Anyways, as you all call bullshit
    I took my door all apart, only to find out that the fucker is riveted in there. wtf??? So I had to take it some place and they did it for like 60 bucks. So to anyone who plans on doing it yourself, have fun....
  • Rhedalert
    Dr. Feelgood
    • 1574
    Ive done it. Drill out the rivets, it took 5 minutes, then reinstall with small nuts and bolts. Like what you'd do with a replacement balljoint.
    Brian
    3400 SFI V6, 4T60e
    • patgizz
      The Plaid Bandit
      • 1071
      took me 20 minutes per front door. i cut the rivets with the air cutoff wheel because i couldnt get the drill to stay centered on the pin in the middle of the rivet.
      • RednBlack
        Wood Hippie
        • Mar 2004
        • 2795
        At's the correct procedure! No drill? A nice sharp chisel will pop the heads off those critters like a chicken! Must have done 50 or so in the same fashion. Book time is 45 mins. 60 bucks sounds a little high. Shoulda been 35 tops. And the motors have always been riveted in.
        • RednBlack
          Wood Hippie
          • Mar 2004
          • 2795
          I have to add why the rivets are there! Aluminum rivets won't wallow out the thin sheet metal if they do get loose. (never seen it) Your window motor torques back and forth. Ever feel your door panel move when your window bottoms out? If a bolt comes loose, and wallows out the holes....Guess what? No window action! And VERY hard to fix! I always replace with aluminum rivets, cheap kit from any Lowes or Home Depot. Easier and faster than bolts too.
          • Rhedalert
            Dr. Feelgood
            • 1574
            There's always those nylon-lock nuts that won't come loose. On the job I did I used lock washers and red loctite. No worries.
            Brian
            3400 SFI V6, 4T60e
            • RednBlack
              Wood Hippie
              • Mar 2004
              • 2795
              I can still pop a rivet faster than you can reach around behind all that crap and put a nut on!
              • Rhedalert
                Dr. Feelgood
                • 1574
                You said reach around.....and nut....
                ...and behind .
                Brian
                3400 SFI V6, 4T60e
                • RednBlack
                  Wood Hippie
                  • Mar 2004
                  • 2795
                  The rivets hold better than bolts in this situation! By design. LMFAO! HehHeh! FIRE!
                  • Rhedalert
                    Dr. Feelgood
                    • 1574
                    I dunno, I always thought the Phantom Cutlass came with a 2.8.
                    IN B4 Dictator Bendam Hussein lox it! :P
                    Brian
                    3400 SFI V6, 4T60e
                    • Anonymous
                      God I love ZR1 Vette's
                      • v6h.o.
                        • 1418
                        damn rights.. simple to put in.. you forgot to add in the words "bid daddy" in there rednblack.. LOL. :P
                        i always cut them off with my die grinder...
                        (big daddy is the name of a brand of Large window rivet guns)
                        Colin
                        • RednBlack
                          Wood Hippie
                          • Mar 2004
                          • 2795
                          I use a Chicago Pneumatic Air POP rivet gun. I like that....POP! Quoting AC|DC..."Pull the trigger!" But seriously, if you ever do have a bolt work loose, you are in one hell of a mess. I learned that lesson a long time ago on a 71 Monte. I didn't know how to weld then and it cost about 75 bucks to fix it. Would be more like 150 now.
                          • 5speedz34
                            • 301
                            What about zipties?
                            -Tony
                            • dykz34
                              • Jan 2004
                              • 793
                              What about reliability?
