LP Conversion - Questions
  • nixtux
    • Nov 2007
    • 282
    Just throwing the idea around. I haven't done much research on this yet but it would
    be a fun little change over.
    Any pointers on where to start buying up parts would be helpful. I've come across
    various kits, so it's weening out the winners from the losers.
    Cleaner fuel, cleaner engine, I like. I think it may loose some power but I'm not
    concerned with that.
  • 86FieroSEv6
    • Feb 2010
    • 527
    You won't lose any power, it is just a different type of fuel with different metering requirements. Check around your local area and see if anybody is using it in their fleets and talk with their mechanics a bit. The only drawback is the lack of valve lubrication but there are work arounds for that as well. Just be sure to take extra precaution with the fuel cell and the fuel itself. Also, whatever you do, don't cheap out on the regulator.
