l67 trouble
  • payback
    • Mar 2004
    • 64
    l67 trouble
    has anyone ever had these same problems?? ok this is for my dads '99GTP with the l67, actually has low miles engine bay pretty clean....
    the problem is it starts and runs fine for 3-7 seconds the just dies with no codes...it did throw a po403/po405 code (bad EGR), once, but hes also been disconnecting some so idk bout that... other than that it will not throw a code but the TCS light will not turn of.
    im leaning more towards the ridiculous TPS sensor failure common to the 3800's or PCM. but the fact that the TCS light wont go off is supposed to mean an emissions related issue.
    does anyone have any ideas?
    '96BerettaZ26- Med Adriatic Blue- FINALLY swapped '04 Impala 3400, Comp Cam, Comp 26986 springs, TCE lifter springs, WOTTECH Comp ported U&LIM, TCE 65MM TB, LM 4t60e~~~Looking for 3400 Downpipe
  • Weatheralls Auto
    Spinning out of control
    • Dec 2009
    • 536
    It wont stay running? Theft issue or Fuel pump resistor
    Starts stalls restartss and stays running? MAF dirty or dying
    As of April 2
    Engine: 2006 SV6 3500 LX9
    Trans: 2002 Getrag F23 5speed
    Injectors: #36 GTPs
    TB: 65mm TCE
    Maf: 1999 3400 Montana.
    Beverages: Ice Cold CANADIAN.
    • Weatheralls Auto
      • Dec 2009
      • 536
      TCS Traction Control System?
      As of April 2
      Injectors: #36 GTPs
      TB: 65mm TCE
      • WrathOfSocrus
        • Jan 2008
        • 318
        Not a 60 degree but that might help.
        • payback
          • Mar 2004
          • 64
          no it will start first try everytime then just die, im under the impression its the fuel pump resistor as its just not throwing codes. unfortunatly i live a state away from him so its hard to troubleshoot.
          hes gonna do the fuel pump resistor bypass (thanks for the w-bod posting) first. if its not that its gotts be theft det. system related (bad chip in the key)
          but the TCS (yes traction control system) light still bothers me that it wont go out, the owners manual says if it wont go out its an emissions related problem.
          hes also going to clean out the MAF, but
          ......nevermind the cars running he did the fuel pump resistor bypass, cars running perfectly!!!!!!!!!!!!!!
          thanks to all that responded...much much appreciated!
