ok guys, bear with me, I bought this 95 camaro, I was given 2 sets of keys, 1 key the resistance is reading 1046 or 1.46 the other key 1041 or 1.41. how can I know what resistance my vats system is. I know Im allowed 2 variance, but its way over that.
Vats question???
Tags: None
I think there is some confusion with the loss of a zero. 1046 ohms is 1.046K ohms. 1041 ohms is 1.041K ohms. Within a margin of error I would say both keys have the same resistance value.
I don't know much about VATS but there have been a number of threads here recently about it. I'm sure a search will help you get closer to solving your problem.
http://vats.likeabigdog.com/ care of a very quick google search.Originally posted by likeabigdog.comThis chart is for any GM product, Buick, Cadillac, Oldsombile, Chevrolet, and Pontiac that has a VATS key (single or double-sided.)
VATS # (K)OHMS (Set your meter to the 20k ohm setting)
1覧覧 0.402
2覧覧 0.523
3覧覧 0.681
4覧覧-0.887
5覧覧-1.130
6覧覧-1.470
7覧覧-1.870
8覧覧-2.370
9覧覧-3.010
10覧覧3.740
11覧覧4.750
12覧覧6.040
13覧覧7.500
14覧覧9.530
15覧覧11.801-60v6's 2nd Jon M.
As I said in the chat box, a set of resistors at the right value to equal the key chip value. Find the wire that runs from the key switch for the VATS hammers. Splice in the resistors between the two wires on the PCM side. You may even make a small module that can be unplugged. Simple radio shack circuit board and a solder pen will work well.
I was going to make a plug set up for my resistor combo. Unplugging it would render the car useless and no common thief will figure that out fast enough. Neat part is the car won't start with the proper key either. Great way to protect the car from teenagers or who ever. When they get your keys and try to start it, it won't.Last edited by TGP37; 08-28-2011, 09:44 PM.1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
