I had a cheap flux welder at one point and it would trip my 20amp garage outlet with it's full 90amps at the gun. Takes voltage to make voltage, you are in fact limited by the 120v, specially because a 120v oulet can only go to 20amps. The TIG will occasionally pop the 60amp double breaker at the shop when over 200amps welding output.
Most versatile welding gas?
The Pro-mig 180 is 230V not 120. I probably won't buy another 110V welder. I ended up getting the welder I was looking at for $430 out the door. not as good of a deal as I hoped for, but a good one non the less.Originally posted by ForcedFirebird View PostI had a cheap flux welder at one point and it would trip my 20amp garage outlet with it's full 90amps at the gun. Takes voltage to make voltage, you are in fact limited by the 120v, specially because a 120v oulet can only go to 20amps. The TIG will occasionally pop the 60amp double breaker at the shop when over 200amps welding output."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
The one I Linked to earlier in this thread, the Lincoln Pro Mig 180Originally posted by ForcedFirebird View PostWhat one?"I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
What in god's name are you building to pull that much amperage on a tig?Originally posted by ForcedFirebird View PostThe TIG will occasionally pop the 60amp double breaker at the shop when over 200amps welding output.
5/8" steel brush guard for a 4-wheel ATV.Originally posted by 3400-95-Modified View PostWhat in god's name are you building to pull that much amperage on a tig?
Thats not 60* or BMW related, you did that off work hours correct? If your boss finds out your using company materials on personal projects your ass will be canned....Originally posted by ForcedFirebird View Post5/8" steel brush guard for a 4-wheel ATV.
HAHA!
it can be done without a spoolgun! but a spoolgun would make things so much easier!"I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
Did you feed aluminum wire full length through a mig gun?
That's not a good idea. The first time it boogers up in the tip, it will double up inside the torch feed and get stuck.Originally posted by 3400-95-Modified View PostDid you feed aluminum wire full length through a mig gun?
Agreed, but how else could he have done it without a spool gun?Originally posted by ForcedFirebird View PostThat's not a good idea. The first time it boogers up in the tip, it will double up inside the torch feed and get stuck.
yeah, I spent more time fixing birdnests than I did welding! I'm going to get a spool gun before I try again.Originally posted by ForcedFirebird View PostThat's not a good idea. The first time it boogers up in the tip, it will double up inside the torch feed and get stuck."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
This is the only downfall of my welder... I have no idea if I could find the spool gun addition for it since its so old and the TIG I got is only DC... I've seen them selling on e-bay complete with the spool gun but for an obnoxious cost. Then again I really don't need to weld aluminum often at all.
Man, that looks OK as long as it penetrated, which by the looks of it it did.
You can grind that to perfection, easily.
I was thinking of buying a nylon liner for my MIG and going to town with it and try aluminum.11.92 @ 122 MPH 3400 91 Cavalier Z24 Intercooled S/C. -totalled-
