32v northstar question
  • Luminaz4Life
    • Jul 2004
    • 20
    i was told a northstar 32v v8 will drop in a lumina or bonnevile with almost no mods?!,it sounds too good to be true,so can someone please tell me if this guy was lying or not?
  • sharkey
    • Jun 2004
    • 2061
    im not sure on this, but im sure it would require custom mounts, the 4t80e tranny, computer, axles, possible even hubs, rad, and lots of other things.
    • Rhedalert
      Dr. Feelgood
      • 1574
      Maybe a Bonne, but it will not fit in a Lumina. There just is not enough room.
      Brian
      3400 SFI V6, 4T60e
      • dohcfiend
        King Chalupa
        • Jan 2004
        • 2351
        i have seen one in a gran prix. but i don't know about it dropping in. i am pretty sure it will require modifications.
        • ProjectMM
          • Mar 2004
          • 170
          i don't know about the mods, but the new GXP bonivlle will have the north star motor in it!
          2002 Pontiac GrandAm GT1
          3400 v6
          TOG headers
          RSM 62MM T-body
          FFP underdrive pulley
          GRANATELLI MAF
          Ported upper intake
          MSD DIS 4 ignition box
          MSD Wires and coils (pending)
          Venom high flow fuel pump (pending)
          • bluebomber
            • May 2004
            • 23
            How can it go in with "No Mods" if you have to switch from a front wheel drivetrain to a rear wheel drivetrain. That alone is plenty of "Mods", unless you could find a way to mount it to a 4T60, LOL!
            1994 Grand Prix SE 4dr - Brilliant Blue Metallic
            Magnaflow Hi-Flow (And Bashed) Cat
            2.5\" Split Dual Exhaust
            Two Flowmaster 40 \"American Thunder\" Mufflers
            7\" Cone Cold Air Intake
            FFP Poly Motor Mounts
            16.320 @ 83 MPH w/ 2.296 60\'
            • Gemmer
              • 240
              4t80 is a transaxle
              • v6h.o.
                • 1418
                even though there was no mention of switching to RWD. for a RWD setup the 4cyl, and V6 4L60E's will bolt up to the northstar, but will require cutting and notching the bellhousing for the starter nose...
                but the Northstar is FWD (in everything previous to the XLR, and SRX)and uses the 4T80E transaxle.
                as to if it will fit? hard to say. yes they are in the new bonneville GXP's. we have a few here at the dealership.
                Colin
                  A little decoding on the tranny model numbers GM has set.
                  4T60E- First number designates 4 gears (3 + overdrive) IIRC. T means transverse layout (FWD, like GP's, Luminas, Cuttys), 60, don't remember, and the E designates it's electronically controled by the ECM.
                  4L60E- all the same as the 4t, but the L means longitudnal (RWD) like in Firebirds, Camaro and a few other RWD cars).
                    • 9191
                    60 has to do with the torque rating of the tranny. Its not really significant to a specific value, but the higher the number, the higher the capacity..
                    45 -- low
                    60 -- med
                    80 -- high
                    • brian89gp
                      • 554
                      The N* won't fit in a first gen w-body, unless you want to move the firewall back a few inches and find some place else to put the radiator. I hear that it will barely squeeze into a 2nd gen though.
