thought I fixed it Headliners woes strikes back.
  • packardbell
    • Jul 2014
    • 91
    Anyways I tried to stick the sagging headliner by spraying some 3M super 77 adhesives. Well it worked for a few days and then it started to sag again. Now the entire headliner is blocking my rear view so I had to remove the whole headliner off.
    The 3M super 77 adhesive is all over the place and wondering how to approach a good long lasting repair of this. There is a thin layer of some foam that GM used and wondering what, how and where to find this? Any help is highly appreciated.
    took quite some time to remove all the super 77 and original foam
    under the roof looks great still.
  • packardbell
    • Jul 2014
    • 91
    trying to reuse the old headliner but i would need some thin sheet of foam. any ideas?
    • 1988GTU
      LB62LHObbqftmfw
      • Nov 2005
      • 2475
      JOANN has closed down, but your crafting journey doesn't end here. Discover fabric, yarn, sewing supplies & more at Michaels, your new creative home.
      • carbon
        Procrastinator
        • 388
        +1 JoAnn Fabrics sells a foam backed jersey material similar to what GM headliners were made out of in the 80s, 90s and early 2Ks...
        Edit: I looked at the website, but I have no idea what it would be listed under... I could walk into my local store and point it out with no problem though
        - Ben
        • packardbell
          • Jul 2014
          • 91
          that would be awesome to replace it with the same stuff GM used. I was thinking of using that carpet stuff for boom boxes but the color would not blend in and stick out like a sore thumb. Is the cloth wide enough? thanks man.
            Get what JoAnn fabrics sells... I have some that will be going in my car and yes it's foam backed like original.
            A second writeup...
            • 1988GTU
              LB62LHObbqftmfw
              • Nov 2005
              • 2475
              That right there is why I just provided the overarching site link!
              • AleroB888
                • Nov 2009
                • 249
                While we're at this, does anybody know about the factory process that is used to make shaped carpet trim pieces, like the grey ones lining the Alero/GrandAm trunks? They are sort of flexible but still retain their shape.
                • carbon
                  Procrastinator
                  • 388
                  Probably a heat activated process... with a mold, a press and some kind of plastic or epoxy backing that will flash at a low temp to prevent damage to the carpet. I dunno.
                  - Ben
                  • packardbell
                    • Jul 2014
                    • 91
                    shipping to canada costs an arm and a leg especially for a car over 25 years old. Hmm, might be more cost efficient to just get some grey color boom box carpet and glue that on.
                    • carbon
                      Procrastinator
                      • 388
                      You seriously don't have a fabric store in Canada? No one sews up there? LOL
                      The other option you could look at is vinyl... sub box carpet is just... I dunno... meh.
                      - Ben
                      • packardbell
                        • Jul 2014
                        • 91
                        original velcro fasteners
                        • 1988GTU
                          LB62LHObbqftmfw
                          • Nov 2005
                          • 2475
                          go to a shop that offers aftermarket sun-moon roof installs. If they are of no help with providing you material or a POC, then just paint the ceiling black!
                          • AleroB888
                            • Nov 2009
                            • 249
                            Here's something interesting.... I went to a local fabric shop (Hancocks) and they had headliner foam-backed fabrics, real lightweight stuff. I got some of that to test out, and started to take some some stuff labeled "Headliner Adhesive" with it and the lady says "You don't want that, my friend tried that on his car and it came off after a few days." Then she said to try 3M 74 (Foam Fast) because it won't dissolve the foam. They had another 3M adhesive, I think it was #90, heavy duty, or high strength, something like that. I asked what that was for, and she says "Anything but foam," lol
                            • carbon
                              Procrastinator
                              • 388
                              Congrats... you now have an itchy ceiling. LOL
                              - Ben
