Front engine trike
  • Bajavwbus
    • May 2012
    • 1
    Front engine trike
    I plan on building a front engine trike using a GM v6. My question is would it be better to use an ssei supercharged engine or the special dohc a friend had in a lumina I believe. It's more for the exotic look over all out power. I plan to ride this thing to hell and back. I'm thinking auto trans and corvette rear.
    It has to be reliable and easy to wire as a stand alone system.
    Input gladly accepted.
    Like this.
  • gar70614
    • Oct 2008
    • 330
    L67 is tall with the s/c ide vote just a 3500 with a 7730 ecm, easy to wire and relaible, better yet ls with newer vette transaxle, also look into jaguar dana 44 irs diff, mite be cheaper than vette rear
    Sent from my SM-G530T using Tapatalk
    • 45es
      • Oct 2010
      • 75
      The 7730 ecm is a good choice although considering this is an open air vehicle I would look at the 1227727 ecm. Same attributes as the 7730 but comes in a weather tight case.
      Ed
