3900 Drawing
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    #46
    You still not listening. You thinking the worng way. You are comparing an auto with shitty gears to a 5 speed with nice close ratios. If said car was running a 2004R with real nice ratios and not the stupid high gap ones that a 4T60 uses then you will lose.
    • Manitcor
      • 573
      #47
      Originally posted by PlatinumZ34
      Now that we have that settled , back to the 3900. If the engine is making power using the best possible technology available, how do you intend on modding this engine to make more power???
      First the obvious is that being VVT and a 2 stage intake there will be PCM tunes that could boost performance quite a bit. (Tuning from other VVT engines gain anywhere from 15-25 real HP from tuning).
      Also the obvious would be pullies, headers, better exhaust and im sure theres plenty of room for porting and if someone were to take the challenge a bigger TB.
      Internals wise there could be cam regrinds that allow you to use vvt to take advatange of either higer or lower RPM ranges more effectivly. Then of course with the beefy bottom end (steel crank, forged everything) you could put a good CSC or turbo application on it and tune it to do quite a bit I imagine.
      1995 Monte Carlo LS
      3400 SFI 60v6
      • Gemmer
        • 240
        #48
        does the 3.9 have VVT like the 3.6 or just dual intake runners?
          • 9189
          #49
          Here is GM's press release on the 3900...
          http://www.60degreev6.com/modules.ph...artid=8&page=1
          • Gemmer
            • 240
            #50
            Well alot has changed over time and an automatic tranny will woop the piss out of even the best gear slamer any day.
            The more gears you have (with proper gearing) the longer you will stay in your powerband and the more gear based mechanical torque you will have the option to make.
            hence a CVT tranny (with basically infinite gear ratios between the highest and lowest) will rev right to your peak RPM power and stay there all the way down the track.
            A 6 speed with proper gearing wont be as perfect as a CVT, but it will tend to stay in the power range pretty damn well
            a 4 speed has 33% less gears to work with in staying in the proper range.
            Now alot of the time the instant shifting of the computer will make up for the lack of gears, but not when you are going through the twisties...with a 6 speed you always have a good gear to drop down to.
            Soo, unless its a 6 speed auto with manual shift buttons (like ford has) than a manual tends to be better overall
            • Manitcor
              • 573
              #51
              yes variable intake and vvt
              1995 Monte Carlo LS
              3400 SFI 60v6
              • geoffinbc
                • 5831
                #52
                Well a simple form of VVT. Really just varriable cam timing. It can only advance or retard the cam. It cannot adjust timing and overlap like the 3.6L VVT
                • TheProfessor
                  • 869
                  #53
                  sounds right
                  let ive it up for cluster fucked motor
                  long live the LQ1 (3.4 TDC)
                  I Like V660s
                  Does Chevy make beer
                  ~Jayme~
