Running with supercharger disengaged
  • my99regalgs
    • Nov 2004
    • 3
    Got a 99 Regal GS,
    would like to know if I will trip any SES's or do any damage to the engine while driving if I remove the supercharger belt until I have time to replace the supercharger ?
  • robby1870
    Squaddoosh
    • 584
    Might throw a code, but definitely shouldnt hurt your engine
    Robby Whitesell
    2006 Pontiac G6 GT
    1985 Toyota Pickup DLX
    • korbendallas68
      • 3400swap.com •
      • 553
      I heard people do that some times. Doesn't seem like it would hurt it. Might make it runs a little funny... who knows.
      1995 Grand Am GT
      3400 V6 / 4T60-E / Engine Swap
      3400 Engine Swap Guide Version 2.5 is Available!
      www.3400swap.com
      • TheProfessor
        • 869
        yeah if your cool with the 8.5 compression ratio and if the computer knows that the extra air isnt entering the engine
        I Like V660s
        Does Chevy make beer
        ~Jayme~
        • TrailMug
          • Oct 2004
          • 22
          Would pulling air past stopped supercharger impellers cause a significant flow restriction?
          • mfewtrail
            ~600hp worth of 3.1's
            • 170
            It will not hurt the engine...enjoy the lack of power. By the way, WHY do you plan on doing this?(I'm asking out of curiosity). Oh yeah, this is a 60* V6 board, you own a 90* V6....so you will find more relative info/more help over at clubgp.com or the w-body.com board(not being a dick, just trying to be informative..)
            Matt F.
            TGP 1/4 mile times
            http://photobucket.com/albums/y33/mfewtrail/
            1990 TGP Coupe VIN Database
            • GPXSS
              • 588
              Air cannot get past the impellers, its why it has the ability to compress. There is a bypass valve in the rear of the blower. Say hello to a 35mm'ish throttle plate.
              I modify stuff
              • Anonymous
                I know on our small block chevy, the motor alone pulls enough air to turn the rotors with vacuum on a Weind 142 blower.
                But doesn't the supercharger on a L67 run off of the serpentine belt? If so, don't remove the belt. It will stop the alternator from charging, the water pump from pumping, AC, and everything else.
                • dbtk2
                  • Feb 2004
                  • 349
                  The engine will turn the rotors itself with the vacuum, therefore sucking air in, but there will be an EXTREME lack of power. It would have low compression, a VERY restrictive intake, and a computer thats giving it way too much fuel, so you really wouldn't want to drive it like that. It wont hurt anything since the supercharger runs off a seperate belt than all of the other accessories, but I don't understand WHY you want to take the belt off... What exactly is wrong with the car???
                  You said you need to replace the supercharger...why? M90's outlast the lift of 3800's other than the coupler, which is cheap and easy to replace. So I can't see why you would need to replace the blower...if its making boost WTF is wrong with it???
                  Shawn
                  99 Grand Prix GT
                  • TheProfessor
                    • 869
                    the supercharger is run off a seperate belt not the surpentine
                    I Like V660s
                    ~Jayme~
                    • xtremelumina92
                      • Feb 2004
                      • 120
                      i don't think so! actually i know so
                      • dbtk2
                        • Feb 2004
                        • 349
                        What are you replying to? If you are talking about the belt, I can guaruntee you the supercharger has its own belt and all the other accessories are run off the other belt. I would bet large sums of money on it actually. Now the Series I L67's were a different story...but his is a Series II, they are a lot different.
                        Shawn
                        99 Grand Prix GT
                        • Anonymous
                          I stand corrected, thanks!
                          • geoffinbc
                            Iron Head Enthusiast
                            • 5831
                            Here is a freaking picture to end the argument. SEPERATE BELT!!!
                            • firechiken
                              • Feb 2004
                              • 557
                              ^^ Where's the chain? I thought boat anchors had chains on them? Or at least a rope.
