93 Z34 - Climate Control Panel lights
  • perfimage
    • 58
    I think I already know the answer to this, but alas, I thought I would ask...just in case.
    How does one change the lights for the climate control panel? Both? of mine have gone out and I need to replace them. I had the dash apart and the module out, but it appears the lights themselves are soldered to the circuit board. Is this so? Is there a way to replace them other than replacing the entire module?
    Thanks,
    RED
  • Lyle's GTP
    • Jan 2004
    • 1345
    You may have to do some soldering. I had to do this with my GTP. It wasn't the climate control though, it was the headlight control modual. I think the little 12 volt bulbs are available at Radio Shack. But replaceing the modual is a viable option. If you shop around you can easily get one for 20 bucks off ebay, or maybe from someone on this site. 20-30 Bucks to me, sounds easier than fucking around with the soldering. I didn't have a computer at the time I did mine, and I was a little more ambitious then too.
    Lyle
    • Lyle's GTP
      • Jan 2004
      • 1345
      Fuck, look at this. 20 seconds on Ebay. You can't even buy the new bulb for that price. Damn I'm good.
      http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
      Lyle
      • perfimage
        • 58
        Thanks! but...
        10 minutes to remove the dash pad, R trim panel and module.
        20 mins to disassemble the module and desolder all 6 (six) bulbs.
        $9.00 in bulbs from Radio Shack.
        30 mins to solder new bulbs in place and reassemble module.
        10 mins to reinstall the module, R dash trim panel, and dash pad.
        Not buying a module at least a year older than mine (with bulbs a year older also) and avoiding the likelihood of having to do it all again....Priceless
        RED
        • Lyle's GTP
          • Jan 2004
          • 1345
          So, what you are saying is you did it already? Cool.
          Lyle
          • perfimage
            • 58
            Yep...Done
            Thanks!
            RED
            • Kyles93Z34
              • Dec 2004
              • 347
              O. So there is supposed to be a light behind the climate control. I thought it was just another dumb thing that they forgot to put on including cupholders.
              1992 Lumina Z34
              5 Speed
              Autozone civic intake
              Ultra White lights
              FFP Dogbone mount
              125k miles
              2.5 inch Magnaflow catback from Magnaflow cat
              60degreeV6.com Custom Chip
