NEED: Auto Dimming Mirror Wiring diagram
  • TheDirtyBen
    • Mar 2004
    • 130
    got a factory auto dim mirror w/compass from a 1996 Buick Park Ave. i'm putting it into my achieva and need to figure out the harness. it has 5 wires.
    1)pink w/black stripe
    2)black w/ white stripe
    3)green
    4)grey
    5)orange
    1994 Oldsmobile Achieva (2002 3100 SFI)
    Homemade ram-effect CAI
    K&N cylinder filter
    Poorboy Lowering Kit
    Front STB
  • Rhedalert
    Dr. Feelgood
    • 1574
    RE: NEED: Auto Dimming Mirror Wiring diagram
    does it have maplights? which model is it (pics?) I might be able to dig a diagram up
    Brian
    3400 SFI V6, 4T60e
    • TheDirtyBen
      • Mar 2004
      • 130
      no maplights. GNTX-120?
      K&N cylinder filter
      Front STB
      • Rhedalert
        Dr. Feelgood
        • 1574
        does it have a little clear square button on the bottom, to turn the dimming function on?
        Green is definetly reverse-gear input
        black is def ground
        orange is usually the battery power for the dome lights (tis why I ask if it had reading lamps)
        pnk/blk is usually hot in run (battery)
        Grey- no idea
        is it 1 plug on the harness or 2?
        Brian
        3400 SFI V6, 4T60e
        • TheDirtyBen
          • Mar 2004
          • 130
          there's a black 3-position switch under mirror. kinda looks like this;
          Off < M > C/M.
          other #s on back side of housing are;12055M, I-E13-012580, I-e13-02-6022, GNTX-120, and a bunch of patent #s
          BTW, has one 7 pin harness connector.
          There appears to be either a reset button or a zone button (for the compass) inside the housing beside the "off" side of the switch.
          K&N cylinder filter
          Front STB
          • TheDirtyBen
            • Mar 2004
            • 130
            any idea?
            K&N cylinder filter
            Front STB
            • Rhedalert
              Dr. Feelgood
              • 1574
              I'm due to be at work tuesday, I'll try and print up the wire diagram.
              Brian
              3400 SFI V6, 4T60e
              • TheDirtyBen
                • Mar 2004
                • 130
                i'm gonna try hooking up pink as key-on power, black as ground, and green as reverse signal. hopefully that will work. i saw a site that discussed the mirrors and apparently some mirrors are set up to dim outside mirrors simultaneously. so the two extra wires may be for outside positive and ground.
                K&N cylinder filter
                Front STB
                • HayesPerformance
                  • 783
                  I have the same Mirror and I ALSO need the wiring Diagram.
                  I did find out that the photo sensor on the back of the mirror dims YOUR headlights when meeting traffic
                  1991 Grand Prix STE
                  3.4 DOHC
                  1 of 792 Produced
                  Extensive Mods Done
                  1991 Lumina Z34
                  3.4 DOHC
                  Getrag 284 5spd
                  1 of 30
                    Interesting. Since I've removed my tint on the back glass (peeling) this would be nice to have. And my mirror is starting to oxidize too.
                      • 9191
                      I was wondering how I missed this thread, and then I realized that until today, the last post was in 2004....
                        LOL I didn't even see that... Maybe someone has the solution by now??
                        • merlot566jka
                          • Nov 2006
                          • 570
                          id like to know as well, i just nabbed one of these outa a park avenue
                          2012 Chevy Sonic Turbo 6spd
