Quality Ass-urance
  • RednBlack
    Wood Hippie
    • Mar 2004
    • 2795
    Quality Ass-urance
    Have to share this. Found it in a Water Filtering Maintenance Manual at work...BTW,...It is meant to be funny.
    • Quality Assurance: Piping Specification-WAP 007
    • 1.5.1 All pipe is to be made of a long hole, surrounded by metal, centered around the hole.
    • 1.5.2 All pipe is to be hollow throughout the entire length.
    • 1.5.3 All pipe is to be made of the very best quality, preferably tubular or pipular material.
    • 1.5.4 All acid proof pipe is to be made of acid proof material.
    • 1.5.5 The O.D. of all pipe must exceed the I.D. Otherwise the hole will be on the outside.
    • 1.5.6 All pipe must be supplied with nothing in the hole, so that water, steam, or other stuff can be added at a later date.
    • 1.5.7 All pipe is to be supplied without rust. This is always added at the jobsite.
    • 1.5.8 All pipe is to be cleaned free of any covering, such as mud, tar, barnacles or any form of manure. This will cause lumps under the paint.
    • 1.5.9 All pipe over 500 feet in length must have the words "Long Pipe", painted on both ends so that the fitter will know that this is a long pipe.
    • 1.5.10 All pipe over 2 miles in length, must also have these words painted in the middle, so that the fitter will not have to walk the full length to find out that this is a long pipe.
    • 1.5.11 All pipe over 6" in diameter must be labled "Large Pipe" so that the fitter will not use it as a small pipe.
    • 1.5.12 All pipe fittings must be made of the same stuff as the pipe.
    • 1.5.13 All pipe closures are to be open on one end.
    • 1.5.14 No fittings are to be installed unless specified. If they are, staight pipe becomes crooked pipe.
  • kanchou
    • Mar 2004
    • 96
    RE: Quality Ass-urance
    hehe 'pipular...'
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      LOL
      • Lyle's GTP
        • Jan 2004
        • 1345
        Man, could you imagine being SOOOOOO bumb, that you have to walk a full mile along a pipe to find out it is long.
        Lyle
        • korbendallas68
          • 3400swap.com •
          • 553
          The funnest stuff is when it's actually in the manuals. It's funny cause companies now are REQUIRED to put the most ultra obvious stuff in them or they get their asses sued off.
          Example:
          "Don't not use hair-drier in the shower."
          Duh.
          1995 Grand Am GT
          3400 V6 / 4T60-E / Engine Swap
          3400 Engine Swap Guide Version 2.5 is Available!
          www.3400swap.com
          • bud36light
            • Nov 2003
            • 517
            Also cool enough to have the time to READ A MANUAL at work! You actually read the manuals!!? Hell we just dive in and see whats up! They bring the "reading room" material along later.
            2004 Grand Am GT 3400 ... I had the right to remain silent, I just didn't have the ability.(Ron White)
            • RednBlack
              Wood Hippie
              • Mar 2004
              • 2795
              If the previous "Maintenance Technician" had taken the time to read the repair section of this manual, I would not have had too. It was really a simple fix that caused me to have to work 5 hours on Saturday.
              • Rhedalert
                Dr. Feelgood
                • 1574
                you said pipe.
                Brian
                3400 SFI V6, 4T60e
                • RednBlack
                  Wood Hippie
                  • Mar 2004
                  • 2795
                  Originally posted by Rhedalert
                  you said pipe.
                  Several times!
                  • hamondale
                    • Nov 2004
                    • 93
                    Originally posted by korbendallas68
                    Example:
                    On a kid's Halloween Superman costume:
                    "Warning: Costume does not enable user to fly."
                    Hamondale
                    Third Rail... your ride is here.
                    • korbendallas68
                      • 3400swap.com •
                      • 553
                      lol :P
                      1995 Grand Am GT
                      www.3400swap.com
