93 Z34 Door Ground effects panels
  • perfimage
    • 58
    Hi folks,
    Just trying to find out how the door ground effects panels are attached on a 93 Z34.
    I was headed down the street a while back and heard some slapping on the door and when I stopped, I found the driver door panel hanging out.
    I guess I am looking for part numbers for the clips or other mounting parts for this.
    Any help is appreciated.
    Thanks,
    RED
  • Crimson Fury
    dropped your pocket
    • 111
    RE: 93 Z34 Door Ground effects panels
    is it the panel thats L shaped? the end thats on the rear of the door is attactched by a white plastic strip w/holes for pegs on the door. it slides on to the panel.
    http://www.w-body.com/forum/viewtopic.php?t=24111
    Car Domain site!
    13* cam timing, p&p\'d lower intake, tapered t.b, FFP chip, FFP mount and the 1st lumina w/HUD!!!
    • perfimage
      • 58
      It is the one piece panel attached to the bottom of the door itself that runs from the front edge of the door to the rear edge of the door. Pic attached.
      Thanks,
      RED
      • Crimson Fury
        dropped your pocket
        • 111
        oh! ok!! the loose section, can you see behind it? i'll assume that there are the pegs that hold it on. that white strip that slides onto a flap on that piece, then slides onto the pegs. if there are pegs, try sliding the piece towards the rear wheel or the front wheel.
        Car Domain site!
