computer program
  • dohcfiend
    King Chalupa
    • Jan 2004
    • 2351
    computer program
    any1 have a computer program i could dl where i put in the weight, fdr, shift points, apporximate hp etc... that plots top speed and 1/4 times.
    i would like something like this to play around with for plotting out a revised shift table. my os is windows xp btw
  • Doubt_Incarnate
    I still watch ROBOTECH!
    • Jan 2005
    • 1130
    i have drag 2000, i can burn you a copy. all ive noticed is the later you shift you faster your times, even if it peaks at 4500rpm. not sure about the accuracy. it allows you to put in you frontan area, coefficient of drang, drive type, wheelbase, weight and weight distribution. gear ratios, tire size, you can import the Dyno files fron dd2k.
