100 watt lights
  • Toofastgtp
    • Oct 2004
    • 57
    100 watt lights
    is it safe to run 100 watt lights? on the stock wiring.
    This is for the headlamps
    -2000 GTP - 332/426
    -94 GTP - Stock, But needs new:
    Door, Steeringwheel, fender, windshield and window for new door, and power steering line.
  • Doubt_Incarnate
    I still watch ROBOTECH!
    • Jan 2005
    • 1130
    like 100 watts a peice? i had some 100 watt off road lamps that would start smoking if i wasn't moving. im not sure thats a good idea, youd only have to upgrade the wires from the relays, depending what vehile you have, that could be easy or sort of tight. wouldnt 100 watt be illegal for street use anyways?
    • geldartb
      The Situation
      • May 2004
      • 1994
      i have 100 watt fogs in my z26 the only bulbs i could find at the time
      99 Grand Am GT
      1357 cam 227 233 .050 dur
      515 515 lift 112 lsa
      • Juglenaut
        • 1130
        You'd get more intensity from a high output LED array at the fraction of the power.
        I am back
        Mechanical/Service Technican
        • Guest
          MMMMM, but there will be no projection, no casting of light.
          • X11_STE
            • 386
            It can be done, just not legally. They do sell upgraded wireing harness' to handle the added load so if your good with a soldering gun.... The max legal light you can have in the US is 55watt low/ 65 watt hi. The biggest problem you'll run into is heat, it WILL dry out your brezels and crack the. Of course if you have a good supply, this wont matter. Also, other drivers will think your an ass trying to blind them by driving with your hi beams on. And "some" highway patrols carry light meters in their cars so take your chances.
            Tuning a car is full of compromises. You must decide if you are willing to give up either reliability, performance, or a whole load of cash. Also remember that repairs will seem to come up much more often as you strive for even more performance
            • RednBlack
              Wood Hippie
              • Mar 2004
              • 2795
              Re: 100 watt lights
              It isn't safe to run 100 watts period. Unless you like watching others drive crazy. Or X-Raying deer. You will have more problems than it is worth.
              • Cliff8928
                • 532
                RE: Re: 100 watt lights
                In certain cases you can run a 65w low beam, but that's very limited (The hella 90mm projector units i have in my beretta use 65w H9 bulbs)
                Cliff Scott
                89 BerettaGT <-65W H9 low-beams
                04 AleroGX <-35W D2R low-beams
                Cliff Scott
                89 BerettaGT
                04 AleroGX
