Exhaust Header gaskets
  • firebirdjim
    • May 2005
    • 2
    Hello,
    I have a 1986 GM vehicle with a 3.8L LG2 stock engine. I keep burning up felpro fiber Exhaust Header gaskets every six months. The engine runs fine. I have OEM Exhaust Headers not manifolds.
    I need Metal Exhaust Header gaskets. Soft Copper or aluminum.
    VIN: 1g3cw69b5g4303622
    Tried Perceys, Jegs, Summit. Nobody has V6 parts ?
    Where can I get these metal Exhaust Header gaskets for this engine ?
    I also need intake manigold gaskets.
    Reply directly to:
    Firebirdjim@hotmail.com
    • 9191
    RE: Exhaust Header gaskets
    Is there a reason you double posted?
    Try looking at www.firebirdv6.com for some other help since this site has nothing to do with your engine.
    • Doubt_Incarnate
      I still watch ROBOTECH!
      • Jan 2005
      • 1130
      there is a "w" in his vin, if its a 86 'bird shouldnt it have a 2.8?
      • RacerX11
        • 1060
        If you are burning up exhaust manifold gaskets, there is something else wrong. Fix the cause of the problem. Putting more expensive/robust gaskets on is just a band-aid.
        Check the exhaust manifolds with a straight-edge to make sure they are flat. If they are warped, they won't seal properly, and the gaskets will blow out. This is my guess where your problem is. Also check the head surface for warpage. Although less likely, it could still happen. Are you torquing the manifold bolts down properly?
        Marty
        '99 Z-28 - Weekend Driver
        '84 X-11 - Time and Money Pit
        Quote of the week:
        Originally posted by Aaron
        • eliteweapons
          • Apr 2005
          • 185
          You also might want to check to make sure you don't have any broken exhaust hangers and that you aren't running too lean.
          95 Beretta Z-26
