Sil's page of nothingness
  • sil
    4T60-E killa
    • Nov 2004
    • 723
    just a page to hold my guides and other snippits of info related to 60v6
    allways being updated
  • sil
    4T60-E killa
    • Nov 2004
    • 723
    seat belt retractor
    seatbelt retractor spring rewiding
    i was bored one day putting back the rod that attaches from the key lock to the latch on the drivers side door(the lil plastic clip came off)
    and i noticed the seat belt wasnt retracting very well, it was annoying so i figured it was a good time to see if i can make it work better.. boy was i in for a surprise.
    look familliar ?
    then you are indeed in need of this little write up.
    the spring is wound in "backwards" to the way it wants to bend, and it is held tight against the outside of the cover.
    after about 20 minutes, sore fingers and if you havnt accidently released the spring got mad and threw the whole thing into the ground then it should look like this....no i didnt get mad and throw it on the ground... ahh ok im lying
    now once you got it all together your going to need to pull out the center of the spring carfully hold the coiled section of the spring in while you take your other hand and pull up on the spring a bit till you get it nice and strait, raised about half the width of the spring, or more.
    next you simply slide the spring into the slotted part of the shaft and be carfull here... now your going to turn the whole thing clockwise 6 times, while managing to keep the cover with the spring in it flat as you can against the retractor
    with any luck you should have a nice working seatbelt mechanism once again... next time dont remove the cover just to see whats in there
    • sil
      4T60-E killa
      • Nov 2004
      • 723
      RPO Code - transmission gear ratios
      not a complete listing
      Three Speed Automatic Transaxles
      RPO Trans Name First Second Third
      M40 3L80 2.480 1.480 1.000
      M41 3L80HD 2.482 1.482 1.000
      M65 3L30 2.400 1.480 1.000
      MD2 3L30 2.400 1.480 1.000
      MD3 HM-180 2.400 1.480 1.000
      HM-200C 2.740 1.570 1.000
      HM-350 2.520 1.520 1.000
      HM-400 2.480 1.480 1.000
      HM-425 2.482 1.482 1.000
      Four Speed Automatic Transaxles
      RPO Trans Name First Second Third Fourth
      M10 JF403-E 3.027 1.619 1.000 0.694
      M13 4T60-E HD 2.921 1.568 1.000 0.705
      M13 4T60-E 2.921 1.568 1.000 0.705
      M15 4T65E 2.921 1.568 1.000 0.705
      M45 Aisin-AW AF33 4.685 2.942 1.923 1.301
      M57 A245-E 3.639 2.006 1.295 0.892
      M76 4T65E with PTU* 2.921 1.568 1.000 0.705
      MD7 4T65E 2.921 1.568 1.000 0.705
      ME8 4T60 2.921 1.568 1.000 0.705
      ME9 440-T4/F7 2.921 1.568 1.000 0.705
      MH1 4T80-E 2.960 1.626 1.000 0.681
      MN3 4T65E 2.921 1.568 1.000 0.705
      MN4 4T40/45-E 2.960 1.626 1.000 0.681
      MN5 4T45-E 2.960 1.626 1.000 0.681
      MN7 4T65E HD 2.921 1.568 1.000 0.705
      MS7 A240-E 3.639 2.006 1.295 0.892
      MU4 A246-E 4.005 2.208 1.425 0.981
      MU5 U341-F 2.847 1.552 1.000 0.700
      Four Speed Manual Transmissions
      M20 HM-117 6.555 3.580 1.700 1.000
      MC0 Getrag 4.020 2.300 1.400 1.000
      Five Speed Manual Transaxles
      RPO Trans Name First Second Third Fourth Fifth
      L73 Pontiac LeMans F16 3.410 1.950 1.270 0.890 0.710
      M79 LeMans F13 3.550 2.390 1.300 0.890 0.730
      M86 Getrag F23 (5T45MI) 3.58 2.02 1.35 0.98 0.69
      M94 Getrag F23 3.58 2.02 1.35 0.98 0.69
      MG1 HM-282 3.500 2.190 1.380 0.940 0.720
      MG2 HM-282 3.500 2.050 1.380 0.940 0.720
      MG3 Getrag F23 3.58 2.02 1.35 0.98 0.81
      MY7 Early J-car 3.910 2.150 1.330 0.920 0.740
      M35 Getrag 260 3.830 2.190 1.400 1.000 0.810
      M35 Getrag 260 (2003-2004 Cadillac CTS) 3.570 2.040 1.340 1.000 0.820
      M86 Getrag F23 3.58 2.02 1.35 0.98 0.69
      Gear ratio 5 spd
      89 HO
      1st 3.50
      2nd 2.19
      3rd 1.38
      4th 1.03
      5th 0.72
      FDR 3.61
      90 GTZ
      1st 3.50
      2nd 2.19
      3rd 1.38
      4th 1.03
      5th 0.81
      Axle 3.61
      91 GTZ
      1st 3.77
      2nd 2.19
      3rd 1.38
      4th 1.03
      5th 0.81
      Axle 3.61
      92-93 GTZ
      1st 3.50
      2nd 2.05
      3rd 1.38
      4th 1.03
      5th 0.72 fuel saver overdrive
      Axle 3.94
      92-93 Achieva SCX W41
      1st 3.50
      2nd 2.05
      3rd 1.38
      4th 1.03
      5th 0.81 (this gives you the short 5th, AND 3.94 axle
      Axle 3.94
      1994 Quad HOs recieved 92-93 GTZ gears.
      getrag 282....if it came in a L or J body....
      1st 3.50
      2nd 2.05
      3rd 1.38
      4th 0.94
      5th 0.72
      FDR 3.61
      getrag 284....If it came from a W body....
      1st 3.77
      2nd 2.19
      3rd 1.38
      4th 1.03
      5th 0.81
      FDR 3.61
      The Getrag 284...
      1st 3.46
      2nd 2.28
      3rd 1.48
      4th 1.09
      5th 0.72
      FDR 3.67
      • sil
        4T60-E killa
        • Nov 2004
        • 723
        ratio's
        html ripped form some site showing a good amount of ratios for all trannies that bolt up to a 60v6, in zipped format
        • sil
          4T60-E killa
          • Nov 2004
          • 723
          alternator adaptor
          Use your New Alternator with your '94 through '98 Car
          Convert Delco CS130D to a Delco CS130 Alternator
          Installation
          Plug and Play. No modifying.
          Details
          Go to this site to order: http://www.nwreg.com
          Phone: 1-800-242-6367 Fax: 503-239-9996
          • sil
            4T60-E killa
            • Nov 2004
            • 723
            egr adaptor plate
            pics
              • 9190
              RE: egr adaptor plate
              That EGR adapter plate looks familiar.... Kinda like the one I printed off and made from scratch just to piss the guy off.
              • sil
                4T60-E killa
                • Nov 2004
                • 723
                Amount of lift a rocker arm ratio will give you
                To figure out total lift, you'll need the lift of the cam at the lobe. Then, take that value and multiply it by the ratio of your rocker arms.
                (lobelift)*(rockerratio)=liftatvalve
                ie 0.440/1.5x1.6=.469
                some manufactures include the rocker ratio with there said lift
                Pushrod and Preload checking
                http://www.60degreev6.com/GPXSS/pushrodchecking.html
                • sil
                  4T60-E killa
                  • Nov 2004
                  • 723
                  injector size calculations html zipped
                  injector size calculator.
                  injector size calculations html ripped from some site zipped up ready to download
                  • sil
                    4T60-E killa
                    • Nov 2004
                    • 723
                    Body codes
                    M Astro van
                    L Astro van AWD
                    S S10/S15 GMC
                    T above with 4WD/AWD
                    B Caprice Impala SS RWD
                    A Celebrity source of 1227730's
                    L Corsica/Beretta These also have 1227730's
                    N early Grand AM, Ciera, Skylark
                    N present, Malibu and above
                    G Full size vans
                    P stepvans
                    W Lumina, Monte Carlo, new fwd Impala, Gp, Ga
                    H LeSabre Olds 88
                    C Olds 98
                    D Cadillac Fleetwood, RWD
                    E Riviera
                    X Citation, remember them
                    T, old Chevette
                    • sil
                      4T60-E killa
                      • Nov 2004
                      • 723
                      4T60-E Tuning - DF Code
                      The two tables where adjustment would be applied are :
                      Tables > EST -Trans >
                      SPARK RETARD TIME 1-2 UPSHIFT
                      SPARK RETARD TIME 2-3 UPSHIFT
                      By setting all values in these tables to "00" hex for example, retard should no longer be applied during shifts.
                      • X11_STE
                        • 386
                        Body codes
                        Actually, I do remember them! As a matter of fact, I own 2 Citation X-11's and a regular Citation (slowly being chopped into pieces). Marty (racerx11) also has some citations.
                        Tuning a car is full of compromises. You must decide if you are willing to give up either reliability, performance, or a whole load of cash. Also remember that repairs will seem to come up much more often as you strive for even more performance
