Wow, no wonder GM is going under.
  • GPRacer
    • Mar 2005
    • 161
    Originally posted by RednBlackCutlass
    Mine come off with a 3/8 ratchet. But I have found stuck ones. I have had success with this. Have someone rap the bolt boss with a hammer as you apply pressure. Or, if you have access, use an impact hammer. Don't hit the caliper. Personally, I would not use heat on cast. Especially on brakes.
    Then, when reinstalling, use new dust boots and anti-sieze. CRC makes a good all around no squeal, anti-sieze.
    Yep.
    Put a decent size (length) 3/8 on it, then a good sized wrench on the other side for leverage. I've never had to torch, burn, ignite, WD-40 any part of my breaking system. Always seemed to have gotten good leverage
    • SHOoff
      • Jul 2005
      • 356
      What'll really get you is when you go to replace the part and you find that GM has changed the design over the years. And you'll either have parts that look different, or use different tools to go in the same hole.
      97 Cavalier RS
      3400, Isuzu MK7
      • Lyle's GTP
        • Jan 2004
        • 1345
        Originally posted by betterthanyou
        LOL fuck man its not a lug nut. Its 38LBS on my truck. Should be close to that on your car.
        Okay, I was wrong. It's only 80 ft/lbs. I checked.
        Lyle
        • Guest
          Lyle
          80 ft/lbs for a caliper bolt?
          • geoffinbc
            Iron Head Enthusiast
            • 5831
            Maybe he means N*m
            • Rhedalert
              Dr. Feelgood
              • 1574
              #21
              it's a caliper bracket bolt, not a slider pin.
              Brian
              3400 SFI V6, 4T60e
              • Lyle's GTP
                • Jan 2004
                • 1345
                #22
                Lyle
                Hah!! I did my rears this weekend. 92ft/lbs on those bastards.
                P.S. That isn't NM either.
                Lyle
                • DEI37
                  • Jan 2004
                  • 516
                  #23
                  Yeah, it's a miserable design to be certain. I've used standard bolts to hold those in place. Was a 19mm, but don't remember length or thread pitch. NEVER had a problem. If they made a T-62 bit, that would be perfect. A T-60 is just a smidge small, and they get cocked in the bolt, and you can have problems.
                  • Hemet8
                    • Aug 2005
                    • 144
                    #24
                    Sorry to add to the mayhem, but i actually LIKE the Aztec. Especailly when it has the AWD, 17"wheels and soild colors. Don't knock it till you drive it AND use it. It may look weird, but it has lots a functionality.
                    Don\'t hate me because I\'m horny.
