stock dsm turbo vs new turbo :D
  • Mac
    • Nov 2003
    • 50
    I think i need to go bigger lol
  • jeremy96gase
    • 93
    wow, quite a differance.
    • Mac
      • Nov 2003
      • 50
      one on the left is a 16G turbo. on the right is a 60-1/Stage V/.82 AR
      the comp housing is all polished up now too
      Hopefully that turbo will help me reach my 600hp (to the ground, awd) goal. If not, i'll have to go bigger.
      • Anonymous
        What motor and car will this be going onto/into?
        • skalor
          • Nov 2003
          • 95
          Hey Mac, what do you think of a FWD DSM owner with a 16G running 25 psi?? I try to tell the kid that it's way too high, but he has the "more is better" mentality. I'm not a 4G63 fan, but that's mostly due to the fact that I'll never own a car with a timing belt. I'm pretty heavy into SR20s...I helped my friends swap one into his '91 Sentra SE-R. He runs a 13.6 on 8 psi, with the stock T-25.
          \'89 Ciera Int. Coupe
          \'89 TGP
          • Anonymous
            Wait a minute.... there is a DSM owner amongst us?
            • Mac
              • Nov 2003
              • 50
              97 Mitsubishi Eclipse GSX, 2.4L stroker engine build up.
              • Mac
                • Nov 2003
                • 50
                well it depends. did he just slap the turbo on his car and crank up the boost? or did he do all the supporting mods. If he's done the mods to support it, fuel injectors, fuel pump, pressure regulator, 3" exhaust, etc, and a nice front mount wouldn't hurt either. Then he should be allright, as long as the engine was in good condition before he started.
                The timing belt isn't a big a problem as people make it out to be. Remove the balance shaft/belt, and replace the timing belt every 60 thousand miles and you should never have a problem with it.
                SR20DET's are good engines. I'd love to build up one for a 280/Silvia conversion (SILEIGHTY).
                my 1G talon, daily driver/winter beater runs 12.46
                • Mac
                  • Nov 2003
                  • 50
                  yes there is a dsm owner amongst you I was refered here, trying to figure out what's up with my parents Grand Am.
                  • v6h.o.
                    • 1418
                    DSM's are fun, a friend of mine from winnipeg has a sweet talon. this year he was running low 12's still tuning the car, he just picked up this new one, after his built up previous car burnt to a crisp from a freak fire...
                    whats your setup mac?
                    Colin
                    • Mac
                      • Nov 2003
                      • 50
                      This is for the 97 Eclipse GSX
                      -2.4L 4G64 block
                      -Stage 4 head
                      -9:1 pistons & rods
                      -stroker crank
                      -272 intake/exhaust cams
                      -aem adjustable cam gears
                      -K&N filter
                      -custom made intake piping
                      -sheet metal intake manifold
                      -T3T4 60-1 Stage V .82AR
                      -custom exhaust manifold
                      -Tial 38mm Wastegate
                      -T3T4 O2 housing
                      -custom 3inch full exhaust with electronic cutout just after the downpipe
                      -3 inch high flow cat
                      -havn't decided on muffler yet
                      -custom upper/lower IC piping
                      -spearco front mount
                      -850cc injectors
                      -bosch high cap fuel pump
                      -aem ems
                      I'm sure i'm missing a shit load of stuff, but thats the jist of the engine mods. I've tore the whole car apart and rebuilt it fromthe ground up. Nothing was left untouched.
                      • Anonymous
                        ahhh, I see. I couldnt understand what a DSM owner was doing here... Most of my friends are big into DSMs. I know a bit about them, but most importantly is that they HAUL ASS! (and break all the time :P )
                        • Mac
                          • Nov 2003
                          • 50
                          this is for my 90 Talon TSi awd
                          -rebuilt 6 bolt stock 2.0L engine
                          -stock internals
                          -K&N filter
                          -cyclone intake manifold
                          -20G turbo
                          -2nd Gen exhaust manifold
                          -supra side mount IC
                          -550cc injectors
                          -high cap fuel pump
                          -sfac
                          • Mac
                            • Nov 2003
                            • 50
                            they only break all the time if you abuse them and don't do regular preventitive maintenance. Much like any other high hp car.
                            • Anonymous
                              No, DSMs break all the time (when pushed). Preventative maintenance only goes so far. You obviously don't mod a car that you don't intend to push hard.
