GM Overhead Cam Engines Named Among Industry's Best
    • 9189
    PONTIAC, Mich. ? Two of General Motors newest, high-performance overhead cam engines ? the 2.0-liter Ecotec Supercharged and 2.8-liter V6 Turbo ? have been named among the industry?s 10 best engines of 2006 by the editors at Ward?s Communications.
    2.8L V6 Turbo
    ?A sophisticated mid-displacement V-6 and turbocharging are a remarkably effective combination,? says Visnic. ?GM and Saab have created an impressive performance-car engine with high specific output and the thrill of turbocharging.?
    The 2.8L V6 Turbo is the newest addition to GM?s contemporary global V-6 engine family. All engines in the global V-6 family share traits that include a 60-degree lightweight aluminum cylinder block with iron cylinder sleeves, an aluminum structural oil pan and aluminum cylinder heads, dual overhead camshafts and four valves per cylinder. The 2.8L V-6 Turbo builds on those strengths with components and technology developed with Saab specifically for the turbo system, variable valve timing, and a variable fuel pressure system to ensure smooth idle and driving characteristics.
    The 2.8 turbo system features a unique, twin-scroll turbocharger. It has an integral bypass valve and is fed by two exhaust ducts ? one from each cylinder bank. Separating the exhaust gas pulses with two compressor zones improves gas flow and reduces energy loss. The turbo system?s charge cooler promotes performance by reducing the temperature of inlet air.
    Delivering 250 horsepower at 5500 rpm and 258 lb-ft of torque from 1800 ? 4500 rpm, the 2.8 V6 Turbo is standard globally in all 2006 Saab 9-3 Aero models, which includes the Sport Sedan, SportCombi and Convertible. It is also featured in Europe in the Opel Vectra and Cadillac BLS.
    The 2.8L V-6 Turbo is built at Holden?s Port Melbourne, Australia global V-6 engine facility.
  • OldSkoolGP
    That guy over there
    • 930
    And for whatever reason, we'll never see it over here. Why don't they bring that kind of innovation to the U.S?
      • 9189
      Uh, its currently available in the Saab 9-3, so it is here in the US.
      • geoffinbc
        Iron Head Enthusiast
        • 5831
        It should go in the Solstice and the Sky. That will give that little MX5 something to complain about.
        • SHOoff
          • Jul 2005
          • 356
          I saw that posted on ClubSi.com, along with the other 8 motors making up the 10 best. Nissan's 3.5L running DIG is getting 306hp, was on the list. Just wondering if GM will step it up and start running Direct Injection.
          97 Cavalier RS
          3400, Isuzu MK7
          • geoffinbc
            • 5831
            The VVT's are equipped for it.
            • Magic
              • 8
              In Australia we have a 3.6 version called the alloytec.
              Comes out standard as either 175kw or 190kw at the flywheel.
              We have a turbo kit which turns the 175kw to 330kw.
              Runs 335.5 HP at the wheels thru a 4 speed auto with 3.45:1 LSD
              Magic
