guage lights
  • j-13gtp
    • Jul 2004
    • 60
    guage lights
    Here recently two of the lights in the guages have gone out can anyone tell me how to replace them or find new bulbs.
    1995 3.4 DOHC Grand Prix gtp
    cold air intake, high flow cat, dynomax mufflers.
  • napatiger
    • 490
    Inspect the bulb
    prolly just a bulb like in a flashlight, maybe radioshack?
    Summit must have something.
    pull the pod, the light is an easy install. Is it fused?
    BTW I just got pods for my three gauge pillar.
    Oil pressure
    Trans Temp
    A/F ratio
    95 MC Z34 Black
    • j-13gtp
      • Jul 2004
      • 60
      I think you misunderstood me, im talking about the lights in the factory gauges.
      • napatiger
        • 490
        oohhhhh
        good luck.
        ebay will sell whole clusters....
        but I would check all the fuses first.
        95 MC Z34 Black
        • patgizz
          The Plaid Bandit
          • 1071
          its not bad. you have to pull the cluster and the bulbs twist in and are located on the back. i'd hit the junkyard and grab a handful of them
          • j-13gtp
            • Jul 2004
            • 60
            Thx, but is there any way that I could buy the bulbs new.
            • Manitcor
              • 573
              most mid-90s GM clusters use standard 194 bulbs mounted into a twist clip that goes right into the back of the PCB. You may have to do a small bit of soldering to get the standard 194 terminals to work in the socket, but its not too big of a deal.
              Heres some pics that may help. All these clusters are from 95-99 montes but should be about the same in your GP
              Get the premium .com domain you deserve. Seamless and professional transactions. Payment plans available.
              1995 Monte Carlo LS
              3400 SFI 60v6
              • Juglenaut
                • 1130
                Most part stores can direct you, if not get a GM number from a new car GM dealer, even if they don't have them get the number so you can do a cross referance on them.
                I am back
                Mechanical/Service Technican
