My new wheels
  • Kyles93Z34
    • Dec 2004
    • 347
    My new wheels
    Here they are. I really like them alot. I just wish i would have gotten 17s but i couldnt afford the tires.
    Kyle[img[/img]
    1992 Lumina Z34
    5 Speed
    Autozone civic intake
    Ultra White lights
    FFP Dogbone mount
    125k miles
    2.5 inch Magnaflow catback from Magnaflow cat
    60degreeV6.com Custom Chip
  • OldSkoolGP
    That guy over there
    • 930
    You wouldn't want 17s anyway, it's harder to get right size tires for them. Those do look good, though. Are they a new AR model?
    • Kyles93Z34
      • Dec 2004
      • 347
      I think they are ICW wheels. I got them from a local tire store for a really good deal.
      Kyle
      1992 Lumina Z34
      5 Speed
      Ultra White lights
      FFP Dogbone mount
      125k miles
      • Guest
        Say what?
        • OldSkoolGP
          That guy over there
          • 930
          It's a little harder to get a size match match for a 225/60 16 on a 17 inch rim, you're usually a tad under or over.
          • Juglenaut
            • 1130
            exactly,
            stock
            225/60 16>135 profile plus 16 inches (406.5mm) for a total of 541.4.
            aftermarket
            225/50 17>112.5 profile plus 17 inches (431.8mm) for a total of 544.3
            Not much, but tire manufactures use different tread depths and usually this is not added to profile, the profile is the sidewall up 3/32 remaining most times. Adds up to about 1/8th of an inch up to 1/2 per manufacture spec.
            The most I have seen without modifications is 560mm with + offset.
            I am back
            Mechanical/Service Technican
            • malibu79007
              • Mar 2006
              • 10
              just put 18"s on it. use a 225/40 R18 tire. go to tirerack.com u can get 18"s
              for less than $100 each(for tires).
              • ez112
                • 258
                225/40/18 is NOT the right tire for a 225/60/16
                Closest you can get is 245/40/18. Go look up the prices of them and then think real hard if you really want them.
                1999 SVT Lightning
                1996 Monte Z34 R.I.P.
                Next BEATER: a C5
                http://www.fquick.com/ez112
                • malibu79007
                  • Mar 2006
                  • 10
                  If you're gonna say someone is wrong, MAKE SURE YOU'RE RIGHT.
                  225/60/16 is 26.7" dia. 245/40/18 is 25.7' dia.
                  That will throw off your speedo 5 mph. (5 mph. for every inch.)
                  245/45/18 is 26.7" dia. And if you're a mexican 275/40/18 is also 26.7" dia. but 11" sidewall to sidewall.
                  Sorry about the wrong size before. It would throw your speedo off 7 to 8 mph.
