Skidpad performance
  • Mach10
    • Jan 2006
    • 232
    I am glad that you are aware of the difficulties with truck/SUV chassis and suspension. It gladdens me that at least one person won't become a statistic.
    I know I'm probably preaching to the converted, but there's a few things I want to get out to anyone who drives a truck/SUV.
    First of all, there's the issue of weight. This is a double-edged sword; Initial starting traction is significantly increased because of increased static friction on the wheels. This means that in inclement weather, trucks will generally get off the line a little quicker. This traction bonus is lost almost immediately, since the tires are now relying on dynamic friction. The weight of the vehicle plays less into this particular equation, depending on the substrate.
    Weight will also make a truck feel more solid while at speed. This is because it takes more energy to change the direction of a truck, since momentum dictates that the truck "wants" to stay in a straight line. This is the transient response that I was talking about earlier. Due to the increased mass, the truck's directional VECTOR will tend towards the direction of travel. Which means that when you tweak the steering wheel, it will resist turning. Many people equate this with high-speed stability. To some extent this is true, but bear in mind that this means the tires have to work extra hard to change the travel vector.
    For those with no prior physics, a vector is simply a combined statement that includes a direction (say, southbound on I-95) and velocity (60mph).
    The problem is when you have inclement weather and reduced traction. The weight balance of most trucks is less than ideal. I feel that the reason so many people end up in the ditch has to do with the fact that they rely too much on the supposed stability. When something goes wrong (brake too hard for a deer) you throw a whole bunch of new forces and variables. On a straight highway, even when iced, it's very rare to find even traction across the highway. "Slippery" can mean almost zero friction on the polished "ruts" and a frosty coating on the centerline.
    If you brake with one foot on the polish, and one on the frost, you have a considerable traction differential. On a truck with a LOT of forward momentum, this differential will cause the truck to ROTATE, since it can't overcome the inertia to make the truck change directions. Remember, that force has magnitude and direction. So does a travel vector. In this particular scenario, you still have the same vector; You're still going southbound on I-95 at 60mph... Only now, you're facing sideways.
    On my little dodge colt this makes the car lurch towards the side with more traction. The car is light, so the force needed to make it change direction is several orders of magnitude smaller. There is some rotation of course. for argument's sake, we'll say that my colt has rotated 20º, and the truck is now at 45º rotation and in a full 4-wheel slide, at 60mph.
    In either car, this is a scary proposition. The vast majority of people at this point will try and correct the skid.
    with a FWD car, this is a simple matter of pointing the wheels in the direction you want to go, and giving it some gas, keeping your inputs at about 1/3 of what you think you would need.
    RWD is a little trickier, since you have to steer out of the skid, you can't just power out of it. Steering into the skid, keeping gas static, being careful not to drop or jerk the throttle. The idea is to get one set of wheels beck in line with the direction of travel, then let the rest of the car settle into it.
    I'm going to venture a guess and say that in an emergency situation, 95-99% of the drivers on the road will steer instictively, but either hit the brakes or let go of the gas. Magazines rave about throttle-response in vehicles, but nobody mentions the role that accurate throttle will play in skid control. Especially in RWD cars.
    Now the weight poses a second problem. Since the car is heavier, it will have more rotational (around the vertical axis, in a skid) mass also. This means that once it starts spinning, it will want to KEEP spinning. It's very tricky to put enough counter-rotational energy into a skid to stop it. But then you have to worry about adding too much correction, and having the tail whip back hard enough to completely reverse the skid.
    Given the skidmarks that I get to see while passing these guys perched on their hoods calling the towtruck, this is what seems to happen every time. They will start skidding in one direction, over-correct, and end up in the ditch opposite to the original skid. All the cases I saw showed the telltale striped skidmarks of ABS brakes pulsing the tires, or else a flat polished skidmark from start to finish.
    Now, it gets even more complicated in 4x4 terminology. The major problem with 4x4 at any kind of speed is that the front and back driveshafts tend to be locked together (unless you're lucky enough to have a viscous coupled AWD setup... Not that common in trucks). This means that your capacity for skid correction is reduced, because both front and rear wheels are turning at the same rate.
    Especially in the case of extremely poor traction, this means that all four wheels have to "catch" at the same time to stop the slide. If the car is at all yawed over, all four wheels are relying on the drag-coefficient of the rubber vs. the ice. Anyone who's driven on ice will know that with the wheels turning in the direction of travel, you have a LOT more traction than if you lock up.
    With one set of wheels turning freely, they will "grab" anytime they are moving at the same rate and direction of travel. The only thing you can do is keep the wheels pointed in the direction you want to go and give it some gas. The hope is that the thrust from the engine will eventually point the truck in the right direction. Given that most of these situations occurs because something bad is happening up ahead, this rarely happens.
    The 4x4 spinouts I saw had similar characteristics, except that the skid they started tended to continue until they hit the ditch. Best I saw was a full 540º. Part of the problem I think is that people assume that 4-Hi on most trucks is a "whenever I feel like it" mode. You can't do it on concrete because you'll wreck your differential. But they do it on Ice because it helps them off the line faster. Most 4x4 manuals warn about taking it over 70kph (40mph?) citing drivetrain damage. Nevermind the fact that you lost whatever cornering stability you had since you will be essentially gripping with one tire only; the outside rear tire. The rest are trying to turn at a different rate.
    *pant*
    *pant*
    *pant*
    I think I'm about done my rant. Anyone else at work, angry, and bored?
    • Doubt_Incarnate
      I still watch ROBOTECH!
      • Jan 2005
      • 1130
      lol you should write books or something.
      Youre pretty smart, must be in school still or have been through a lot of it. ironicly the suv i purchased is a ford explorer, the very same suv i've seen in ditches on the way to and from work in the winter, one was upside down.
      and yes, i am concious of the limitations of truck/suv chassis, unlike most peopel it seems. i do understand and realize that they are not designed to be "sport" of any kind, but how else would ford/chevy/dodge have sold so many if it didnt have "sport" somehow integrated into it? trucks are unballanced, thats a consequens of having an empty box for a bed, suvs, a little more ballanced since there are seats and inteirior from stem to stern.
      4x4 does give a false sence of control, true it was never meant for highway use at 70mph during inclement weather, anyone who has a 4x4 and has taking the time to read the manuals and pamphlets would know that. un fortunately most drivers look at the book long enough to figure out the clock/radio/nav/toys and then just forget its there. 4x4 is meant for low speed off road situations where all 4 wheels can slip a little to prevent transfercase damage. thats irony, 4x4 requireing slippage.
      Sadly most people are ignorant, and it kills them. it also makes others suffer through having to clean up their mess, and otheres having to wait through it.
      i could also go as far to let my true colors shine... but i dont think i'll do that right now.
      • Mach10
        • Jan 2006
        • 232
        The major problem with SUVs are the gooshy suspensions they usually come with, since the target market is generally the luxury (or wannabe luxury) crowd.
        What happens with these trucks, and I think it's a fncking CRIME is that the makes BUILD them with specific problems wo lower their exposure to lawsuits.
        Firstly, the brake bias and suspensions specs from the factory are designed to give them (if at all possible) a huge amount of oversteer, and to make the outside tires slip badly on a corner.
        The tradeoff of having a soft comfy suspension is that the body-roll on an already top-heavy truck puts it in danger of spontaneous rollover when Wendy H. Soccermom tries to swerve around the family cat at 20mph.
        An ideal suspension on these trucks would help greatly with straightline stability and cornering stability...
        But then there would be a LOT more spontaneous rollovers. Anyone remember the first year of the Jeep Liberty? The first car C&D tested that flipped itself over on the skidpad. Jeep/Chrysler complained that it was a surface defect on the skidpad... Like any city streets are better?
        Honestly, I don't see a real use for SUVs beyond the cliched status symbol. As a work-truck they are almost useless except for specific exceptions, as a family-hauler a FWD is more stable, gets better economy. We can argue this till the sun comes up, I know. Then again, I'd like to see a car market like Europe has. We've grown too content with our big cars and wide streets. Its a waste. I'm no tree-hugger, but seriously, for everyone that complains about gas, if everyone bought a compact/subcompact, gas prices would fall through the floor. The oil companies can't STORE gasoline. It HAS to be sold or it goes bad. Yeah, my Fiero is a guzzler, but it gets maybe 8000km per year of use. My Colt is sitting at nearly 10,000 for 3 months. (long commute).
        For reference, the Limeys consider my 1.5L Colt to be excessive in the displacement department
        • Doubt_Incarnate
          • Jan 2005
          • 1130
          wannabe luxury, thats me!
          as far as economy i get about 18 city and 23 hywy. granted, suvs are useless to most, a station wagon or minivan does the same thing, just an suv is usualy 4x4 and actually has a frame so you can pull a boat out of the water up a ramp without stressing the unibody, or showing everyone your stupid as you melt your tires off in a cloud of smoke and slip backwards into the water . my uncle had a rwd aerostar, and the camper he was pulling about ripped the hitch off, i dunno how, it was a simple pop up camper and was within the load limit. you just cant beat a frame mounted hitch.
          i rember dad trying to pull a small 17ft sail boat out of the lake, with an escort, don't ask me why, its an ethnic thing. he'd put a hitch on a set of roller blades if the had some. the car was great in the winter, and great on gas. heck it was even fun in the turns. but as far as playing in the water... moms awd bravada ripped that boat from the lake after the escort torched its clutch.
          everything has its place, its just usually in the wrong one. its kinda like guns. guns and suv's dont kill people, the operaters do. that kinda makes the guns and suvs into victims. if everyone was concious of their own driving, suvs wouldnt roll since people would understand that its not like their car and they need to be more aware and concious.
          • Mach10
            • Jan 2006
            • 232
            BWAAAAHAHAHAHAHAHHHAA
            "Showing your true colors" indeed?
            • Doubt_Incarnate
              • Jan 2005
              • 1130
              #21
              yeah, that poor car got beat to death. hopefully i didn't inherit to much from him gene-wise.
              • Mach10
                • Jan 2006
                • 232
                #22
                "The best thing that ever happened to me was when my parents told me I was adopted!"
                • EspanolaGuitarista
                  Visionary
                  • Feb 2004
                  • 254
                  #23
                  Think about....
                  putting in Nitrogen in your tires. They keep the tires far more cool, essential in a rig like yours, plus, they can increase your tire life by 40 percent!
                  • sharkey
                    • Jun 2004
                    • 2061
                    #24
                    i pulled out my car and driver from may 1986. they roadtested the 86 z24, here are the specs.
                    0-100ft- 3.3 sec
                    0-500ft- 8.8
                    0-1320- 16.7
                    1/4mile speed- 83mph
                    0-30mph- 2.5
                    0-60- 8.5
                    0-80- 15.5
                    60-0- 153ft
                    80-0- 274ft
                    lateral G's 100' - .83g
                    slalom mph- 63.1
                    just a note, i find it funny. the ferarri 328 gts they tested in the same magazine got its ass handed to it cornering wise by the cavalier.
