Parts Cleaners
  • korbendallas68
    • 3400swap.com •
    • 553
    Parts Cleaners
    I never seen how a part-cleaner machine works. Would I be able to build one?
    It would heat up the de-greasing solution thats mixed with water in a pan or whatever. Then having a pump cycle the fluid through the heating tank. It would come out the 'hose' in the top with hot degrease, then filter through a drain on the side troughs.
    1995 Grand Am GT
    3400 V6 / 4T60-E / Engine Swap
    3400 Engine Swap Guide Version 2.5 is Available!
    www.3400swap.com
  • El_Diablo
    STFUniversity
    • 917
    most use heat and or vibration in combination with a solutin but the sonic cleners just use heat and vibratn
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      The one at my dads work uses heat and high pressure nozzles above and below the parts. The parts sit on a rotating expanded metal mesh screen and are blasted with hot de greaser/cleaning solution at high pressure.
      • El_Diablo
        STFUniversity
        • 917
        ive seen manual units like that but never an automated one
        how well does it work? i would suspect its not the best thing for heads or carbs but now im curious
