burnout vid
  • prodigy_16
    • Feb 2006
    • 32
    burnout vid
    me doing a burnout in 1979 camaro... 350 with the following specs:
    block: new gmpp 350 4 bolt main
    heads: gmpp performance vortec 64cc chambers
    cam: 226* intake 234* exahust @.050 .498 .580 valve lift 1.5 full roller aluminum rockers
    intake: edelbrock performer rpm air-gap
    carb: edelbrock performer 750 cfm
    headers: flowtech afterburner
    electric fan and fuel pump, 10:1 compression it makes 400hp and 450 ft.lbs on performance trends dyno simulator program (cant afford desktop dyno)
    tires are 275/40/17 rear, and yes its spinning both tires
    If it's worth doing, it's worth doing the right way.
  • patgizz
    The Plaid Bandit
    • 1071
    had an 80 back in the day when digital cameras took the worst pics ever.
    mine had severe weight reduction, harwood 1pc front end(whole fenders/nose assembly was 19#). harwood hood hinged in front. 8pt roll cage, subframe connectors, HD springs, dropped all around, rancho adjustable sway bars, summit racing th350, 400hp fuel injected 350, 98SS dash, console, and seats, fuel cell and rear mount battery, NX hitman nitrous system, 17x9.5 in back with 275/40 and 17x8 in front with 245/45.
    you = join nastyz28.com if you've not already.
    • prodigy_16
      • Feb 2006
      • 32
      already did but thanks.
        Nice Burnout!
        I gotta get a burnout vid of my T/A one of these days...
        • jp_grasshopper_007
          Power Level:1,000,000
          • Mar 2006
          • 120
          WEAK
          because I\'m not Canadian
          • prodigy_16
            • Feb 2006
            • 32
            Originally posted by jp_grasshopper_007
            WEAK
            weak?? I only used one gear and i was in my driveway. let me get it on the street for ya... then we'll see what you think
            • prodigy_16
              • Feb 2006
              • 32
              got the trans done today, will be making a new burnout vid, this time it will have more than one gear, also doing it in a remote industrial area to acoid accidents and trouble, any requests on what you would like to see??
              • Kyles93Z34
                • Dec 2004
                • 347
                DOUGHNUTS!!!!!! Maybe i'm just hungry.
                Kyle
                1992 Lumina Z34
                5 Speed
                Autozone civic intake
                Ultra White lights
                FFP Dogbone mount
                125k miles
                2.5 inch Magnaflow catback from Magnaflow cat
                60degreeV6.com Custom Chip
                  • Mar 2006
                  • 120
                  weak?? I only used one gear and i was in my driveway. let me get it on the street for ya... then we'll see what you think [/quote]
                  yes, weak.
                  your hp & tq #'s are not even close.
                  I'm not trying to be a dick but you're living in a dream world.
                  you might want to dial in your carb better it's running fat.
                  • prodigy_16
                    • Feb 2006
                    • 32
                    i know it is running rich, it is like that on purpose, it has open headers, and when we take it to the track it runs a nitromethane mix in the gas wich requires it to be a little rich. a predator carb is replacing the edelbrock soon so it wont be an issue. and how would you know if my hp and torque #s arent close? would you like a detailed list of exactly everything i put in it, and everthin i have done?? maybe you are just a little full of yourself
                    if you are running the specs on a dyno program dont forget the cam LSA (111*) intake centerline (107*) intake mainifold heat (neglagable-edelbrock performer rpm air gap) coolant temp (160*) ambiant temp and humidity (dyno standard 60*) the fact that i am running gmpp PERFORMANCE vortec heads not standard. and the reduction in parasitic loss (roller rockers, electric fan and fuel pump, no smog equipment just alternator, wp and power steering, and a low drag high volume waterpump.) maybe, JUST MAYBE... you are getting a little ahead of yourself??
