54 belair project updates
  • patgizz
    The Plaid Bandit
    • 1071
    original front suspension:
    new front suspension:
    custom drop tranny crossmember
    4 link rear(original was narrow little leaf springs)
  • patgizz
    The Plaid Bandit
    • 1071
    little info.
    original 4 wheel power drums, factory gigantic power steering system, 235ci 125hp inlines 6 with powerglide, torque tube rear w/ narrow leafs.
    now:
    TCI mustang II front end-
    -2" drop springs - 300#
    -2" drop spindles
    -11" disc brakes
    -upper and lower tubular control arms with poly bushings and screw in balljoints
    -power rack and pinion
    -chevelle tilt steering column
    -custom steering shaft with flaming river billet u-joints
    rear end - custom fitted to car
    -4 link equal length traditional bar setup
    -panhard rod
    -3/4" QA1 rod ends on all bars
    -250# QA1 coil over springs
    -10 bolt 1967 camaro rear
    -11" disc brakes
    engine/trans:
    1995 chevy L05 block
    -bored .030
    -nodular crank
    -"pink" rods
    -flattop pistons
    -GMPP billet hydraulic roller cam
    -GMPP vortec heads (9.5:1 CR)
    -edelbrock RPM vortec intake
    -heavily modified 600cfm holley vac sec.
    -HEI ignition
    summit racing th350 trans
    -2,200rpm stall converter
    -functioning column shift
    -custom thick tube race driveshaft w/ spicer HD joints
    -custom built crossmember
    • RednBlack
      Wood Hippie
      • Mar 2004
      • 2795
      Lookin' good Pat!
      • RidgeRunner
        • 971
        Man...
        I need a job so I can move someplace with a garage. That way I can get my '67 project underway.
        60v6's original Jon M.
        • slick94prix
          • Jan 2005
          • 201
          So what all have you accomplished since I helped you finish up that rear suspension?
          1992 Miata B Package
          1995 Regal 3100
          1996 Firebird LT1 T56
          • patgizz
            The Plaid Bandit
            • 1071
            lots. steering column is mounted, steering shaft is made, column shifter is hooked up, the plate for the firewall for the brake pedal setup is made just need to drill it for the booster and pedal. pedal and mount are made. gas pedal will be installed as soon as the brake pedal is in and located. then i can finish ripping out the stock wiring harness and install the new.
            • patgizz
              The Plaid Bandit
              • 1071
              today: fun with fabrication.
              http://www.chevytalk.org/threads/sho.../0#Post1505158
              • patgizz
                The Plaid Bandit
                • 1071
                • RebelGT
                  • 642
                  awesome
                  26+6=1
                  • firechiken
                    • Feb 2004
                    • 557
                    Nice!
                    • Kyles93Z34
                      • Dec 2004
                      • 347
                      Love the dash. Also like the covers on the motor, those flames are awesome.
                      Kyle
                      1992 Lumina Z34
                      5 Speed
                      Autozone civic intake
                      Ultra White lights
                      FFP Dogbone mount
                      125k miles
                      2.5 inch Magnaflow catback from Magnaflow cat
                      60degreeV6.com Custom Chip
