Originally posted by BlackJack
10 or 12 point Roll Cage
To pass tech, you couldn't do that anyway and would have to be a new piece, not added to.Originally posted by BlackJackyeah, that's what I'm apparently going to have to resort to, but I wouldn't slug it, I'd probably sleeve it, and even then, like you said, more weight.
Give Jesse James a call
With the propper equipment making a cage isn't really that hard. I've done them on several very fast go carts and dune buggies. A guy at a local muffler shop said he'd build one for my Trans Am for $200 :P
yes, I still intend to OCCASIONALLY carry passengers in the back, but not down the strip
as far as I know, which isn't much, the main concern here is that the halo be positioned over the front seating area. The rear braces should't make a difference on that little bit farther they need to extend over the rear seating area to the rear shock towers.
No, strike that. I think the 2dr and 4dr are the same length, so no modification should be necessary. The 2dr just has longer doors and no center pillar, to facilitate back seat access. The 4dr is the same length overall, so I just need the rear braces to follow the ceiling line a little farther before dropping through the package tray to the towers.sigpic
it won't be safe to carry passengers in the rear of the car with the cage in. In a lot of cases its not safe to drive in a car with a bars around your head not wearing a helmet (padding or no padding those bars will do serious damage) So you're going to have to choose, safety or passengers, you're not going to be able to have both.Originally posted by BlackJackyes, I still intend to OCCASIONALLY carry passengers in the back, but not down the strip
