heater core replacement help!! 98 olds achieva
  • durangoman
    • Jul 2006
    • 9
    hello, can someone tell me how to replace the heater core in a 98 olds achieva, any help appreaiated!
    • 9189
    Get a Haynes manual. It will involve either pulling the dash or most of the dash. Without a book, it isn't something I would attempt. I've done it myself on a 94 Beretta and it took me 6 hrs plus a week waiting for a part I broke. I had it done on my 98 Blazer and it cost me $1200 and 3 days w/o the car. Definatley not something that can ve easily explained on a forum...
    • 95SleeperAcheiva
      ArtofOlivia"PocketRocket"
      • Jun 2006
      • 694
      remove the center console. if automatic, there is a clip holding the shifter handle on, you need to put it in neutral first so block the wheels.
      pull the cover under the steering column, the one just above the pedals.
      remove the heater duct work from driver's side.
      disconnect heater hoses.
      remove heater core cover.
      remove heater core.
      reverse install.
      • durangoman
        • Jul 2006
        • 9
        thanks alot!!!
