93 and earlier allowed to remove catalytic converter ?
  • sil
    4T60-E killa
    • Nov 2004
    • 723
    edit[scrweed up on topic] should read " 92 and earlier allowed to remove catalytic converter ?"
    i hacked sawed out my cat and i brought it to parts source to get some piping and the guy there had informed me that any vehicle 93 and up are required to have a cat by law and removing it can result in a fine(if caught)
    now is this true?
    if so is the year correct?
    ps: dont hack saw a cat out with one of those mini hacksaws lol
    took me forever using one of these
  • patgizz
    The Plaid Bandit
    • 1071
    any car ever equipped with a cat must run one by federal law. they started using them in 1975. not to say i adhere to those laws, but it is the law.
    • robby1870
      Squaddoosh
      • 584
      yeah, if it came with one, its gotta have one. I dont agree either, but don't ever use a hacksaw, lol. At least upgrade to a sawzall.
      Robby Whitesell
      2006 Pontiac G6 GT
      1985 Toyota Pickup DLX
      • sil
        4T60-E killa
        • Nov 2004
        • 723
        well that makes sense if it came with one its gotta run one
        lol.. eesh it was fun with the little hacksaw
        sears is having its sears dollar days and i seen a decent skils reciprocating saw for cheap
        actually im applying for a job at sears int he ahrdware dept. if i get the job ill buy lotsa tools
        but for now im limited to poor mans methods hehe
        • HayesPerformance
          • 783
          Depends IF you have Emission laws in manitoba.
          In Alberta there are none.
          Hence, I had removed mine. And YES YOU DO NOTICE A POWER GAIN.
          I really didn't think it would make much of a difference but it did.
          IMO
          Do they smog the cars in Manitoba???????????
          If not, unless you have someone from EPA laying under your car I will tell you that almost every automotive shop there would give a rats ass if had one on or not.
          THATS YOUR CHOICE THOUGH!
          1991 Grand Prix STE
          3.4 DOHC
          1 of 792 Produced
          Extensive Mods Done
          1991 Lumina Z34
          3.4 DOHC
          Getrag 284 5spd
          1 of 30
          • sil
            4T60-E killa
            • Nov 2004
            • 723
            i agree hayes, i think its pretty slack here in winnipeg
            i have honestly never ran one, although if i had an aftercat o2 id jsut throw on a high flow cat....
            and i have allways ran my hooker aero chamber and have never gotten pulled over...
            then again im in the habit of just barly letting off the throttle when i pass the police lol, i can get the car VERY quiet
            well there are no smog testing here, only the free, "come if you want to test your car days" every once in a while, so im not worried
            • sharkey
              • Jun 2004
              • 2061
              every province/state is different. here in bc, you are required to have a cat if the car came with one, however only in the lower mainland (not a big area, but has more cars than anywere else in the province) were you have emmissions testing do you get checked. if you dont have one, you fail the test and cant insure your vehicle.
              what people do to get around it is either weld cat heat sheilds to a peice of pipe to pass the visual, or being that most of the time you fail without it, have a cat on flanges thats easily removed and replaced with a straight pipe or resonator.
              • sil
                4T60-E killa
                • Nov 2004
                • 723
                double post..
                • sil
                  4T60-E killa
                  • Nov 2004
                  • 723
                  heh...
                  emmisions tester: dual exhaust?
                  me: uhhh, yea thats it dual exhaust...
                  me: *pulls the lever to switch from his "cat bypass" to emissions exhaust"
                  • patgizz
                    The Plaid Bandit
                    • 1071
                    here in ohio(8 counties anyway) we have a visual to look for the cat and a sniffer test on rollers @ idle and 35mph. i did that to my truck(heat shields over the exhaust pipe, screws holding them together, no seams) and passed the visual AND the sniffer test. shows you how much a cat really does to reduce emissions...
                    • DEI37
                      • Jan 2004
                      • 516
                      What kind of truck? That's pretty good!
                      • patgizz
                        The Plaid Bandit
                        • 1071
                        89 silverado 350 TBI. passed with almost exactly the same #'s as my dad's 90 suburban with same engine, and he had a new catco cat on it(and his engine/sensors/injectors are brand new, mine sat for 6 years).
                        • lone_wolf025
                          • Sep 2006
                          • 19
                          Here in Chicago for most OBD I vehicles they plop 'em on a dyno and do a drive trace. If you fail you get readouts along the entire curve for HC and CO. Really old cars just get the sniffer at idle IIRC and for the older cars the limits are a joke. The new OBD II they just plug in a scanner and make sure you have a functioning MIL. I'm not sure if they do a visual inspection or not though...
