quick injector question
  • sil
    4T60-E killa
    • Nov 2004
    • 723
    ok i seen some injectors(6) and a certain store, they are brand new and CHEAP and they look like multec 2's they are long and skinny but there kinda WHITE
    wtf they say ford, but they look like they have gm plugs.
    im thinking of buying them and getting them flow tested and stuff
    but should i check the ohms on them first incase i can use them
    what should the ohms be ?
  • treeZ24
    i wanna go fast!
    • Mar 2004
    • 251
    high.. 12ish
    hint.depending on what you need for fuel, there are gm multec2 design injectors you can use.
    got zap-straps?
    89 Z24
    13.886 @ 96.16 mph
    street trim - slicks
    • sil
      4T60-E killa
      • Nov 2004
      • 723
      thanks for reply treez24
      i think those ones at the store are for the 96ish contours
      and i believe that they are 19# @ 36 psi <-- countour svt
      so if i ran them in my car id get like 20 lb/h if im lucky they could be 16# @ 36 psi
      i guess there not really worth buyin :P
      i was doing some massive research lol
      damn... they were extreeeeeeemely cheap too
      • Manitcor
        • 573
        IIRC there are some injectors commonly used on the 4.6 mustangs that work as well.
        You can also use the newer injectors for the 00+ 3400s, you will need to splice on the newer style connectors onto your harness.
        1995 Monte Carlo LS
        3400 SFI 60v6
        • sil
          4T60-E killa
          • Nov 2004
          • 723
          4.6 mustangs, hmm
          you dont happen to have apic of the motor and what year mustangs?
          would be sweet to know what kind of motor i am looking for
          oh the 4.6 mustang injectors, how many lb/h are they @ what psi ?
          • mfewtrail
            ~600hp worth of 3.1's
            • 170
            4.6 mustangs, hmm
            Any 4.6 liter mustang(GT!) from 1996-2004 will have 19# injectors(they'll flow more like 21-22#'s on our typical fuel pressure ratings). Also, Ford 5.0 liter Mustangs have 19# injectors as well as lots of other Ford cars. The injectors in them are really reliable, especially vs. the early GM multecs. I've pulled Ford 19# injectors from early-mid 90's cars that still work fine. Depending on which ones you get, you'll want to ohm them out and check for about 14.5-14.8 ohms.
            Matt F.
            TGP 1/4 mile times
            http://photobucket.com/albums/y33/mfewtrail/
            1990 TGP Coupe VIN Database
