First Track Time This Year
  • bracketracer
    • Jun 2004
    • 112
    I've been waiting for this time to come for months! Fortunately the weather decided to cooperate with my work schedule, and I got to spend a great Test-N-Tune day at Great Lakes Dragaway on Saturday. The weather was pretty good (high 40s - low 50s, humidity under 50%, barometric pressure 29.2, and density altitudes of under 500 feet), but the track was still pretty cold without much rubber build-up, so traction wasn't the greatest.
    I haven't had the Sunbird at the track since last July, and I was anxious to see how it would run with it's new exhaust system. I just had a custom-built 2.5" system (minus cat) welded up with mandrel-bends, and a Dynomax Turbo muffler. It's quite a bit louder, but I wanted to make sure that I didn't lose bottom end power with the bigger system. I designed this system to work for the race engine I will drop in this summer, but I feared that it would be too much for my current tired old motor. I also wanted to test a suggestion from my engine builder to reduce my shift points to improve ET. For years I used the same shift points for consistency, 1-2 at 5600, 2-3 at 5600, and 3-4 at 5000. He strongly felt that this was higher than it needed to be.
    I started the day off using the old shift points to get a baseline. I noticed an immediate improvement in my mph due to the new exhaust system. In past years, I was usually in the 83 to 85 mph range, with a best ever of 87.25 nearly 10 years ago with only 40,000 miles on the car (I now have nearly 152,000). My first run was 85.77, and then I set a new record of 88.33, followed by 85.79 and 87.25. ETs were better, but not great due to traction limitations, I was only able to launch at 2500 on my Drag Radials (I usually launch at 3000). My best ET with this system was a decent 15.742. That compares very favorably with last year.
    I bumped my shift points down to 5400/5400/5000 next, and saw immediate improvement. I launched better (2.109 60 ft) and ran a 15.657 @ 86.39, followed by a 15.679 @ 88.60 (2.159 60 ft, and another mph record). This rivals my best runs of the last 3 years, so I was thrilled.
    Next I bumped down to 5200 across the board. My first run I had a horrible launch (2.307 60 ft), but I still ran 15.889 @ 85.70. Then I launched a little better (2.198 60 ft), and ran 15.759 @ 87.62. The ETs fell off from before, but I felt that shifting even lower would help.
    Next I bumped the shifts down to 5000. It felt strange because the 1-2 & 2-3 shifts came up so quickly, but the car felt like it was flying! I picked up my timeslip and was thrilled with the results:
    R/T - .038
    60 ft - 2.044
    330 ft - 6.266
    1/8 - 9.786 @ 69.53
    1000 ft - 12.851
    1/4 - 15.471 @ 86.52
    That isn't far off the all-time record for the car of 15.416 @ 86.54 when the car only had 40,000 miles on it. The numbers surprised the heck out of me! Now I wish that I had been shifting at 5000 rpm for all these years instead of winding it out. I can only imagine what it might run once the track is a little be stickier so I can launch at 3000 rpm or more! Maybe I'll set a new PB with the old motor before it gets replaced!
    Hope everyone else is getting back to the track and enjoying racing again as well!
    Joe Morgan
    bracketracer
    '93 Sunbird SE 3.1/5-speed 14.869 @ 90.96 Heavily Modded
    '00 Grand Prix GTP Sedan 13.689 @ 100.97 Lightly Modded
    '09 G8 GXP Manual Trans 13.166 @ 106.47 BONE STOCK
