Well I'm fixing to leave for a 1/8 mile track thats only 25 miles from me. This will give me an idea of what its going to run in the 1/4. From what I've seen it will take about a 9.6 to hit a 14. You all are just as well take a guess what its going to run, will post the results in the morning even if its a 11.0 run.
going to the track
Cool! What kind of car is this in? That would be a mid to high 14! What was your mph?1999 Olds Alero 2.4 to 3500 swap (running). totaled by a honda
14.96@91.47 in the 1/4
9.63@74.36 in the 1/8th
what size slick?Originally posted by 923.4v6 View Post92 camaro at 71mph. But only a 1.97 60' and thats leaving at 5500 rpm with slicks. Seems to bog off the line.
id suggest a 26x9x15 hoosier, i used to run those with the do5 compound which is the softest they make. i could get them to slip just the tinyiest bit off the line wich stoped the car from bogging.
the 26x9 is a light tire as well, run them without tubes and around 14-16 psi of air presure
u still on the stock rear and ds as well? if so dont expect either to last long with that kind of abuse off the line
#1 1989 RS - THE L98 AND LT1/LS1 KILLER
1LE SUSPENSION AND BRAKE SWAP,3.1L V6 8.5-1 CR, LIGHTENED CRANK,KB COATED PISTONS, CUSTOM 268/272 DUR CAM, CNC'ED HEADS, PORTED INTAKE,CUSTOM TURBO KIT W/ 67MM TURBO(AKA TO4R/Z) 28 PSI, TCI STREETFIGHTER 700R4 W/ TCI 4,500 STALL,ALL RUN BY A MEGASQUIRT ENGINE MANAGEMENT SYSTEM
#2 95 granprix 3100 all stock for now
ported heads and cam comming soon, megasquirt ems and turbo down the road
Hey Shane, you try the stuff I mentioned in the email? 1.97 is kinda high seeing I could pull a 2 flat with my stock motor and street tires.
74mph is what it did in the 1/4 stock 3.1
u need to slip the clucth a lil bit, or get the tires to just and i mean just break free a bit,if the car dead hooks its just going to flat out bog,u dont make enough power to just dead hook, when it does it pulls the motor down so low were its not making any power#1 1989 RS - THE L98 AND LT1/LS1 KILLER
Just because the tires aren't spinning doesn't mean you are hookingOriginally posted by 923.4v6 View PostNo but it was hooking good that night. It bog when I dumped the clutch. I have 3.73's but I think with the 5-speed it needs a little lower or I need more torque.
You need to transfer the weight. 9" slicks and the right setup will get you in the 1.7's for your 60'. My friend has 275rwhp (cam only v6 - Stock class) and hits 1.69 60's and 12.8's with 26x9" and the modifications I told you about. Fastest v6 stock class fbods are doing 1.5-1.6's.Last edited by ForcedFirebird; 05-26-2009, 10:10 PM.
After changing a few things, if you know what I mean, I'll try those things before going back to the track. 1.9-1.7 should take my 9.5 to a 9.3 mathematically that is which would also be down in the 14's. But now I won't be satisfied unless I get it to low 9's. No then I'll want to hit a 8.
