I've found that my car responds better to timing than anything else. IIRC your timing map is way conservative. I run 24° total at 13psi of boost, about 120 IAT and 50% water/alky injection through a small nozzle (can't remember the size though). I don't know your cam specs, but some overlap should allow you to run even more lead, especially since you don't have turbine wheel blocking your exhaust.
2009 Results (so far) V2.0
'89 Z24 3400 5-speed
TO4E 50-trim/T3 Stage II turbo; 13psi
Quarter mile: 11.95 at 118.7mph
www.khturbo.net
Thanks for the tips.
I blew a transmission last week, same thing again, looks like the spider gears craked in half and it spit the diff pin through the case.
I got a friend to weld me up a diff in another H282 and this time I hope it holds better.
I might add more timing to the mix, but for now, I think I have enough power. haha, I don't need another 10 - 20 - 30 HP if I can't keep a transmission in the car. I want the power "level" where I can BEAT the car and it stays semi-reliable. I am just on the edge of that point now I think.
