Epping NH 12.67@107
    Epping NH 12.67@107
    About time.
    Finally hit my 12 sec pass... I got the 12.97 I wanted with no changes since my 13.078 run so that made me happy. Then the following day I soaked the bottle in the sun and got her up to 900 PSI, Its amazing the difference it makes. The jets are now delivering the amount of nitrous it should be, so I think my WHP gain went from what I used to get (60) up to the rated 100 of the shot.
    Rolled a 12.67@107.47 Unfortunately the last run of the day I had shifting issues and the track was wicked slippery so I aborted to get a 13.2@91 But the day prior, it was the 12.97, 12.85, and a 12.92 all in a row. So consistent 12's is NOT out of the question.
    Here is the 12.67 and 12.97 slip, I left the 12.85 in the car, but I'm uploading the 12.85 and 12.67 vid's
    I just need to get the LSD rebuilt for next year and maybe beefed up to be a bit stronger... Right side of car is caked with rubber, absolutely nothing on the left and you can see the tire only spins when in the water box.
    • Jonpro03
      • 362
      Awesome!
      • Nick-G
        11's or Bust...
        • Feb 2008
        • 224
        Nice times!
        BUILT Turbo 3400/4t65e-HD powered Grand AM in the making.
        • 2.8-350TBI
          RWD FTW!!!
          • Sep 2009
          • 350
          Congratz!
          Originally posted by Mars
          Haha ^ Wrong Wheel Drive.
          No 60ºV6 at the moment
          • ShieldsM
            • Jun 2010
            • 21
            Nice to see the NA's doing 12's, Congrads man. I hope to join you in the 12s club next year.
            Stage 2 Comp WOT-TECH heads, upper and lower intake P&P, street/strip cam, Custom pushrods, TCE LS Lifter Springs, Dimond Pistons 10.7:1, 65mm TB, stage 3 custom cold air intake, heat shield(only for Heat protection on Temp and MAF sensor), DHP Tuner, Adj FPR, #28 injectors, MSD ign coils, talyor wires, S&S header, S&S high flow cat, borla cat Back, all ARP studs, TCE double timing chain with crank kits, Cometic head gaskets, A/C deleted, HF water pump, and so on
              NA's um not quite...
              Its a Sprayed motor.
              12's with a 4t60e n/a is going to take a lot of motor.
              • ShieldsM
                • Jun 2010
                • 21
                Doesn't matter that you are using NOS, it is still N/A. I need NOS to hit 12's too
                  • 9186
                  Nitrous is considered a type of forced induction, not NA...
                    Live life 3.7mi at a time
                    • 4555
                    Nice times, Jon! Car is looking good as well
                    Lulz.
                      Thanks guys
                      I'll update later when I take my diff out to see whats left of the LSD... I have a feeling its going to be really worn after that weekend... The left tire just never spun.
                      • mfuller
                        Mr. Common Sense
                        • Nov 2003
                        • 374
                        Make it easy on yourself and weld the diff.....then they'll both spin.
                        'Course, it won't want to turn that well....
                        I can hear everyone screaming already - a spool in a 'Retta????????
                        Matt
                          Trust me I almost did already...
                          But I thought better of it and realized how much of a bear it would be to drive. Dave also advised me to not do that since when he did it it was a very bad outcome drive-ability wise and he only did that because he was in a pinch.
                          Remember my whole aspect of this car is it's not a track only car. I can take it out on a Sunday drive but also rip a 12 sec pass if I want I used to say 13 sec pass before and it just didn't sound as good... LOL
                            Nice times! Time for a bottle warmer?
                              Hell yeah... The wife wants to buy it for me... LOL
                              But yes, Bottle warmer, Better WOT switch, Home made Delay Timer, Pressure Gauge, and new arming switch setup is due for this winter.
                              And yeah whatever the LSD needs.
                              Its all about consistency now... I've proven its quite fast
