After doing some some compressor map comps. I conclued that a t-61 had the highest efficinecy for my 3.4 (93-95) 15 psi @ 6000 rpm, to be used as a hp street engine. Anyone's input is welcome !
Sizing the turbo compressor
10psi with my 60 trim is easily achievable at 2800 rpms...1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
Isn't a 35R a ball bearing turbo,about $1500 ? Actually of the turbos I checked the t61 had the highest % of eff. but I there are other factors to consider,Like where do I want my boost to kick-in,goal was 400 hp. My pr for 14.7 psi is 2.0 (15 psi is 2.02) airflow is 43 ib/min. The to4e 57 looked good too.Last edited by ezrollin; 01-14-2007, 05:59 PM.
The T series are all older, less efficient designs. Be very careful with the terminology and similar names of many turbos. If you want something cheaper than the GT series of turbos, but with most of the performance, look for the GT series compressor wheels combined with an older T series turbine in a typical T3 or T4 setup. Here are some examples. For under $900, the first two are my favorites.
GT35R compressor wheel in non ball bearing combined with a T4 turbine
Same compressor, but with a T3 turbine
Older T3 and T4 turbines combined with the older 60-1 compressor wheel
325 whp 350 lb-ft
The 57 trim T04E is too small for 15 psi on a 3.4L motor. My calculations were showing about 54 lb/min at 6500 rpm and hitting 43 around 5200 rpm.Originally posted by ezrollin View PostIsn't a 35R a ball bearing turbo,about $1500 ? Actually of the turbos I checked the t61 had the highest % of eff. but I there are other factors to consider,Like where do I want my boost to kick-in,goal was 400 hp. My pr for 14.7 psi is 2.0 (15 psi is 2.02) airflow is 43 ib/min. The to4e 57 looked good too.
I've seen the GT35R from reputable dealers for as low as $1199 shipped. Check Honda-Tech for awesome deals on turbos from their sponsors.
325 whp 350 lb-ft
