Originally posted by napatiger
View Post
Yes, kevin535, you DO need to do a LOT more research, you may know something about diesels, but you show VERY little knowledge about turbos or turbine theory, or even basic engine (fluid) theory. I love guys like you that say "Oh that won't work right because blah blah blah", when people do it and it works VERY well everyday. The only time there is any extended "lag" from using a turbo is because it was improperly selected (for size, trims, etc.), not because it came from a diesel.
You also need to a bunch more research on the 660, since the lowest the 660 was for SCR was 8.5:1, which was back in the early '80s, later versions went to 8.9:1 in both the genI and genII versions, then with the introduction of the genIII a raise to 9.5:1 was seen and later up to 9.6:1, whihc works just fine with a turbo, contrary to the old myth that you had to lower SCR to use a turbo.
Additionally, if you feel we belittle people, that is a personal problem of yours that you are going to have to deal with. The information on these engines is so skewed all over the interenet that we don't want that misinformation to continue on this site, so we will correct you, or anyone else that perpetuates any myth or incorrect information.
