cutlass turbo
  • 3.1cutlass
    • Feb 2007
    • 101
    cutlass turbo
    Hey guys i am new here and the owner of a 91 olds cutlass supreme sl with 50,000 miles and a 3.1. I have been searchin for months for a turbo. I want to create low boost to save my motor and tranny. Recomendations? any help would be great.
  • mechanicman
    • Feb 2007
    • 1
    Just an addition to this post, but I have a 95 Buick Century with same problem. I can't find any turbo kits or anything. Do they even make them? Any help would be greatly appreciated.
    Thanks,
    -Tom
    • timg
      • Feb 2004
      • 718
      For the earlier motors, the easiest option is swapping parts from a Turbo Grand Prix.
      For the later 3100, this is the closest thing I have seen, but it's for the 3400 in the Grand Am.
      There have been talk of kits, but I don't recall seeing and kits for the w-body with the 3100.
      Tim
      325 whp 350 lb-ft
      • 3.1cutlass
        • Feb 2007
        • 101
        the only problem is finding a turbo grand prix unless you know of one?
        • timg
          • Feb 2004
          • 718
          You just have to start scouring junk yards. Sometimes, whole cars come up for $500 on ebay.
          Tim
          325 whp 350 lb-ft
          • 1988GTU
            LB62LHObbqftmfw
            • Nov 2005
            • 2475
            Watch ebay. That is the only thing I can suggest for TGP parts at a decent deal. Goodluck with the project.
            • 3.1cutlass
              • Feb 2007
              • 101
              I just found a used one for $200
              • TurboSedan
                • Jun 2004
                • 218
                i have a '91 Cutlass Supreme with a 3.1 Intercooled Turbo engine and Getrag 282 5-speed transmission. it dyno'd 227whp & 325wtq before tuning, would likely dyno ~255whp & ~360wtq now on a DynoJet. tons of new parts and upgrades since last summer - new 1.7" drop Intrax front springs, upgraded larger '96 W-body brakes front and rear with new rotors and pads all around, new GM balljoints, brand new 245/50 Kumho ECSTA 711s on 16x8 GTP crosslace wheels, new AFCO Racing/TDC adjustable rear coilover suspension, new KYB GR-2 struts & struts mounts all around, new front strut boots and jounce bumpers. Walbro 255 HP fuel pump installed just yesterday. crossover pipe has been rebuilt by M&S Productions with SS flex bellows, turbo has NO shaft play, no smoke etc. Magnecor KV85 wires, M&M Racing MBC, K&N cone filter directly on compressor inlet, TurboXS RFL BOV, custom dyno tuned chip by KAZ MotorSports last November.
                34mm Z34 front sway bar, 22mm Addco rear sway bar, extra shifter and shifter cables, '94 3100 1.6 rockers included but not installed. also have an extra TGP intercooler and intercooler fan that will be included. runs and drives GREAT!very very fun to drive
                gets great gas mileage to boot (wayyyy better than my Regal GS which is stock and not nearly as fast....my Cutlass will blow its doors off). trust me, finding all of the TGP parts separately is a PITA (been there done that) and finding a beater TGP parts car can cost alot unless you get really lucky and find one locally and even then you'd be looking at fixing problems it may have.
                no looking for TGP specific parts or doing any work here, this car is ready to drive, very dependable and quick! $2250 cash takes it and i could deliver halfway if you're interested. this car is also absolutely rust free.
                '91 Cutlass Supreme sedan - 3.1 Intercooled Turbo / Getrag HM-282 5-speed - 13psi / lightly modded
                '98 Regal GS - 3800 Series II Supercharged/HM-4T65E-HD - 180* T-stat, otherwise stock
                GM W-body Forums
                • 1988GTU
                  LB62LHObbqftmfw
                  • Nov 2005
                  • 2475
                  ^ There's your turbocharged cutty. Buy it and save yourself the hassle IF you can.
                  • 3.1cutlass
                    • Feb 2007
                    • 101
                    that would be sweet but i don't have much spare money. Where did you get the lowering springs? And the sway bars?
                    • 1988GTU
                      LB62LHObbqftmfw
                      • Nov 2005
                      • 2475
                      To do a proper TC setup you're looking at spending $1500+... So with knowing that, sell your car for 1000 if it is in tip top running shape (Should be if you're going to turbocharge it) and buy his car with money to spare. Done deal. lol
                      • 3.1cutlass
                        • Feb 2007
                        • 101
                        i would have to sell my car for 2250 to buy hos for 2250
                        • 1988GTU
                          LB62LHObbqftmfw
                          • Nov 2005
                          • 2475
                          Then how do you plan on doing this forced induction modification?
                          • 3.1cutlass
                            • Feb 2007
                            • 101
                            I am working on a job now and saving money. I wasn't planing on doing the project until spring anyways.
                            • TurboSedan
                              • Jun 2004
                              • 218
                              i got the Intrax springs through a group buy on w-body.com. they are front springs for the '95-'99 Monte Carlo/Lumina but they fit all '88-'97 1st GEN W-bodies just the same. the group buy was for the front springs only. the sway bars i bought from other forum members.
                              GM W-body Forums
