TurboZ24 is still boosted, but not as it was....
    • 9189
    He's putting it into an MG.
    • TurboZ24
      • Dec 2003
      • 299
      I did tune it up some, had a few issues. Boost wouldn't hold, so I didn't get a consistant boost level. I had problems getting the injectors to run clean enough at idle, so to fix it, we ended up reducing their effective overall rating, so it ran out of fuel at 9 psi.
      but it didn't do to bad. The boost control issues lead to 8.5 psi at low rpm, but it fell off by 3800 to 4.5 psi, so. 212 wheel HP @ 4.5 psi @ 5050 rpm and 320 wheel ft lbs @ 8.5 psi @ 3300 rpm. I'm sure if I run it at 8.5 psi at 5050, I'd get around 250-260 wheel HP, close to what I was shooting for. I guessed 10-12 psi would be 280ish, so that's close.
      I'm fixing the boost issues, it was a mix of the controller and the BOV. I'm not sure what I'm going to do on the fuel, though. I might just leave it as is and run 8 psi max or maybe 7 and decide in a couple of months.
      As for the car to put the motor into, the Fiero would be a good choice except.... the choice of transmissions sucks. I broke the 5-speed in FWD, I'm sure it would break in a mid-engine setup. I hate autos, so.
      Curtis
      91\' Turbo Z24
      http://www.turboz24.com
      • ezrollin
        • Dec 2003
        • 205
        What are the turbo spec's on the new engine?
        • TurboZ24
          • Dec 2003
          • 299
          that would be a T3 .48 A/R stage 2 turbine with a 46 T04E compressor.
          Curtis
          91\' Turbo Z24
          • ezrollin
            • Dec 2003
            • 205
            Wheren't you using a t60-1 on the other engine?
            • TurboZ24
              • Dec 2003
              • 299
              #21
              the "built" motor was using a T4 .7 A/R p trim turbine with a 60-1 compressor, yes. In the new chassis, it will have 2 GT28RS turbo's.
              Curtis
              91\' Turbo Z24
              • EMX5636
                • Jan 2005
                • 50
                #22
                What are you doing with the old turbo? I have the Fiero that you had helped out with the Haltech tuning... My current 60-1 seems to be almost dead.... I can get a new chra, but maybe I could add a little $$ to your pocket if you are interested in a sale. Let me know, thanks.
                Justin W
                1988 Fiero Formula - 3400sfi with an intercooled 60trim, Haltech, water/meth
                1990 Mitsu Eclipse GSX - parted out
                1991 Galant VR4 #108/2000 - Slammed sedan, built everything
                1995 Kawi Ninja zx7r
                1992 S10 4x4 - lowered/bagged, the dd
                2004 450R MX quad
                • TurboZ24
                  • Dec 2003
                  • 299
                  #23
                  I'd like to get rid of the whole setup, headers, crossover, turbo, and exhaust. If course, the exhaust wouldn't fit a Fiero, but the headers will and maybe the crossover. I'd have to check, though.
                  Curtis
                  91\' Turbo Z24
                  • EMX5636
                    • Jan 2005
                    • 50
                    #24
                    I already built custom headers and crossover for my fiero, so none of that would do me anygood... I'd just have to swap from a t3 to a t4 flange...
                    let me know, also, any pics of the whole setup or just the turbo? thanks,
                    2004 450R MX quad
                    • rickykline
                      • Oct 2006
                      • 345
                      #25
                      pics of the headers and crossover and down pipe installed?? im lazy and dont feel like making my new setup out of stainless ...
                      • 93ztwo4
                        • Nov 2006
                        • 75
                        #26
                        interested in headers
                        • TurboZ24
                          • Dec 2003
                          • 299
                          #27
                          Crossover and headers installed
                          Crossover and headers out of the car
                          Downpipe
                          Curtis
                          91\' Turbo Z24
                          • TurboAlero
                            TurboAlero
                            • Jun 2006
                            • 136
                            #28
                            how much are you asking for them?
                            • 93ztwo4
                              • Nov 2006
                              • 75
                              #29
                              ^ditto on that
