I have been thinking about taking the step but don't know what I should use for a setup. I would prefer to stay with a zex kit because it is easy to use and install but don't know what to do with the nozzle(s). I was thinking about going wet but have heard that is a problem for the plenum. I was also considering using small injectors in the plenum above each intake opening. Any ideas will be appreciated
3100 SFI NOS install
Tags: None
I suggest (if you can afford it) the Holly NOSzle system, highly advanced.
https://www.holley.com/HiOctn/ProdLi...NS/NOSzle.html
V-6 system P/N 08006NOS
Check it out, and also check out the thread under "DOHC Preformance".
Lyle
Well I would either stayith NOS or NX. Havent had a problem with either, tho NX has a much better product. And nos is less espensive.-=1989 2.8 Beretta=-
3x00 Port&polished top end, Crane cam, NX EFI Kit, Manual conversion, 62mm TB, many more..
13.34et@106mph 242whp 326wtrq
--------------Sponsored by-----------------
www.americanperformanceofcolorado.com
