tuning 4 s/c question
  • alainman15
    • Dec 2006
    • 65
    ok me and a friend want 2 put on eaton m90s but we where just woundering what would be considered proper tuning. u know ideas u might have and stuff
    he has a 94 cav 2.2L (i know its not a 60*v6)
    and i have a 91 sunbird 3.1L
    just wounderin i could do so my engine don't go kaboom. im estimating a 5-8 psi of boost.
    the only thing i can think of is a lower temp thermostat and 91 octane fuel.
    Cars beaten in 1/4 mile: 06 Honda Civic DX
    love my 3400
    check out my car at cardomain.com
    search "alainman15"
    And well tuning. You gotta have a way to control fuel for the added boost. RRFPR/FMU or best get a chip burned with TGP code and run a 2bar map sensor and larger injectors that the chip is tuned for and a larger fuel pump. Other than that a colder range spark plug can help prevent knock.
    • alainman15
      • Dec 2006
      • 65
      hold on there what does "RRFPR/FMU" mean
      And does any one know if the map sensor is good considering that the tgp and the bird have the same motor. how similar would the sensors in the 2 vehicles.
      tgp and bird injects r a direct swap right?
      i guess ill do sum research
      love my 3400
      search "alainman15"
        • 9191
        RRFPR - Rising Rate Fuel Pressure Regulator
        FMU - Fuel Management Unit
        • alainman15
          • Dec 2006
          • 65
          ewwww they sound expensive. can i steel a presure regulator from a tgp?
          nevermind mind i guess i don't need 2 steel 1.
          I went and did research and found out that the fuel pressure regualtor, map, and fuel pump r the same in a tgp and sunbird. the only thing is that i don't know how credible my source is. I used the candian tire parts data base
          don't now about the plugs and injectors
          what about my computer what should be done?
          love my 3400
          search "alainman15"
