Turbo recomendations
  • EMX5636
    • Jan 2005
    • 50
    I'm looking to replace my worn 60-1 .63a/r housing turbo with something else. It's on a 3400sfi with ls6 springs in a Fiero. I think I want to upgrade to an .82a/r exhaust housing. Possibly dropping to a 50trim for space reasons... I was also considering a holset hx35. I know the stock cummins ones come with a 12cm housing, which is close to a .82. I will be running between 10-14psi hoping for 350-400whp. Thanks for all your suggestions... later
    Justin W
    1988 Fiero Formula - 3400sfi with an intercooled 60trim, Haltech, water/meth
    1990 Mitsu Eclipse GSX - parted out
    1991 Galant VR4 #108/2000 - Slammed sedan, built everything
    1995 Kawi Ninja zx7r
    1992 S10 4x4 - lowered/bagged, the dd
    2004 450R MX quad
  • EMX5636
    • Jan 2005
    • 50
    all the turbo guys out there... and no one can offer anything?
    2004 450R MX quad
      • 9191
      Its been less than 24hrs... not everyone visits the site multiple times a day. Give it a couple days...
      • timg
        • Feb 2004
        • 718
        Why not have it rebuilt? You should be able to swap to a T04E or T04B compressor housing and the larger turbine housing at the same time. Problem solved.
        Tim
        325 whp 350 lb-ft
        • Guest
          precision SC6152E
          • EMX5636
            • Jan 2005
            • 50
            i don't know if it's worth the $$ for a new chra, and then the housings on top of it. unless you know something that I don't?!
            2004 450R MX quad
            • timg
              • Feb 2004
              • 718
              It may be cheaper to buy a new one. You will need to call somebody like Precision Turbo to ask.
              Tim
              325 whp 350 lb-ft
              • TurboAlero
                TurboAlero
                • Jun 2006
                • 136
                just go to http://cheapturbo.stores.yahoo.net/
                There you could get some turbo for good a price.
                for price on the Precision turbo's hmmm go to www.Arubaspeedshop.com
                They sell precision stuff
                • Guest
                  here is your Precision SC61
                  $550
                  • EMX5636
                    • Jan 2005
                    • 50
                    cool, thanks guys... I just picked up a turbonetics 60trim. still a .63 a/r exhaust housing, so maybe I'll upgrade that.
                    2004 450R MX quad
