i got this 89 camaro... i was wondering what motor was best for boosted aplications like 4.3, 3.8, 3.4, 3.1, 2.8, 3800, 3400, 3100 series and its probably going to be intercooled and also if i could use any turbos like ones off of another v6 off of 300zx etc...
Advice on turbos
Tags: None
only ones i can think of and that are recommended are the the 3.4 DOHC and the (3.4L)3400 SFI motors. the 3800 isnt discussed here.1996 chevy beretta "BRM" Black rose metallic purple. 2.2L 5 speed. pacesetterheader full 2.25in exhaust all the way back into a dynomax ultra flo muffler. FFP UDP, CAI, pioneer head unit w/stock speakers. MRZ stut/shock tower braces. KYB shocks/struts sprint 1.6in lowering springs. 17x8in MB "boost" 5 star rims wrapped in 215/40/17 kumho spt tires
NEW PROJECT: 1993 chevy beretta 3500 5-speed in the works!!!
You have a Camaro (RWD) so you are limited to the RWD blocks, so the XX00 engines are out of the question uless you are a serious fabricator and are willing to put a tubular k-member in. Many people have had good luck with boosting the 60* motors in general. Of course there is no replacement for displacement and if you have access to a 3.4, go for it. If you still want more power, put 3400 heads, pistons, and intake on it.
You should search a little bit and your questions will be answered for the most part
I'd boost the 4.3 out of those choices. It will be the cheapest to build and should have the most aftermarket support.
325 whp 350 lb-ft
Originally posted by ForcedFirebird View PostYou have a Camaro (RWD) so you are limited to the RWD blocks, so the XX00 engines are out of the question uless you are a serious fabricator and are willing to put a tubular k-member in. Many people have had good luck with boosting the 60* motors in general. Of course there is no replacement for displacement and if you have access to a 3.4, go for it. If you still want more power, put 3400 heads, pistons, and intake on it.
Why the tubular K-member? I won't be cutting my crossmember out and replacing it with tubular.
Would you care to enlighten, I have been understanding the issue of room under the f-body's.Originally posted by The_Raven View PostWhy the tubular K-member? I won't be cutting my crossmember out and replacing it with tubular.
BTW, just saw a 3400 placed in a 4th gen f-body that has a tubular front, and it was still a tight squeeze.
Originally posted by ForcedFirebird View PostWould you care to enlighten, I have been understanding the issue of room under the f-body's.
I'm going to modify the 3400 Oil pan, I figured that would be the easiest way. Modfy on the Bench, instead of cutting out the crossmember, plating and welding in a tubular crossmember.
Just FYI, I have a Jimmy, so I also can't just simply unboly this section either.
I will be welding a couple mounts to the lower front of the crossmember, for other things though.
