Compressor A.R.
  • ezrollin
    • Dec 2003
    • 205
    Compressor A.R.
    I have a turbo[Schwitzer] with H trim comp. and P trim turbine .84 ar . What is an easy method to determine the compressor a.r; I know what ar is just need an easy way to measure ar since it isn't on the comp.
  • nocutt
    • 123
    Pics?
    3800 S3 intercooled turbo...
      Live life 3.7mi at a time
      • 4555
      Man, where do you find all these turbos? Or are you shopping still? I don't know if it's the same with all turbos, but Garretts you have to measure the in/ex-ducer of the comp wheel and do the math.
      • Guest
        Measuring the wheel gives you the wheel trim.
        The A.R. is a measurment of the housing, and I have diagrams that show how it has to be measured, I'm not exactly sure how to go about measuring it accuratly.
        If you have maximum Boost, I beleive it shows the diagram in there, I know for sure Turbochargers has it.
          • 4555
          OOPS! Re-read the first post and realized =p.
          • ezrollin
            • Dec 2003
            • 205
            This is one I picked up for a mild boost 305 sbc but decided I'd boost a 3.4 to have something unique and I'd have to change the sbc heads . No pics but could get some.Yes I do have Maxboost,will check and see if I can figure a way to make an accurate measurement.
            • nocutt
              • 123
              Raven, A/R I am sure you know is just a geometric characteristic...measuring it may mean nothing...
              post the pic, how do you know the other specs...?
              • ezrollin
                • Dec 2003
                • 205
                The turbine ar is on the housing. I took the turbo apart and measure it with digital calipers.I'll dig out the digital camera atake some pics.
