Just finished my putting the turbo on my 01 GA GT let me know what you think..
Turbo setup complete
Yes, the oil drain. I guess I'm just having trouble visualizing where it is.Originally posted by schamsy View PostThe drain is going to my oil pan. If thats the drain your referring too. I guess the only drain on the setup so yeah the oil pan from the turbo.
I don't like your wastegate placement as its only feeding from one bank of cylinders which is not a good design. you could see boost spikes and the inability to control boost. Not to mention loss of power.
Also I don't like the SSAC turbo. Or XSPower or wahtever the cheap ebay company is now a days. I doubt it will last but I guess it will work for at least a mock up turbo. I would definately look at upgrading though to a better turbo with a larger trim when that one goes out.
Other then that it looks good.
Do be so concerned with the ebay turbo. I have one and another member here put over 70k on his. The major thing about them is the false advertising on the trims. If you bought the 57 trim (they all say 57 on ebay), it's actually measured to be a 46 trim. They are good for about 350-400hp depending on the VE of your engine.
My wastegate placement collects gasses from all 6 cylinders without backfeeding into the header like yours does. With yours its only able to efficiently dump exhaust from 2 cylinders while the exhaust from all the other cylinders are going to feed back toward the wastegate in the opposite direction they should be flowing killing power, efficiency and flow. Horrible design
Also I am running a Precision SC6152E turbo. Not from "some guy in Cali" Its obvious yours is an ebay special turbo. It looks just like all the others. What did you pay $250 for it?
regards
