RSM SUPERCHARGER for 3.1
  • jackflat0021
    • Feb 2007
    • 26
    i have i 91 buick regal coupe i want to S/C it i found the RSM SUPERCHARGER for 3100 and i wanna kow if it will work the same or better because of the lower compression
    and if you can please list some sugested mods to compliment this one
  • zofo61
    Banned
    • Oct 2005
    • 436
    What tranny do you have and what motor in the Regal......Didnt know RSM had a 3100 application.
    • angrysk8r
      • Apr 2007
      • 15
      Technically you could run more boost and a smaller pulley with lower compression. As far as supporting mods, definitely get some exhaust mods (headers or PEMs, bigger DP, high flow cat, etc). Also iirc the rsm preprogrammed "tune" is horrible, they also say to put the maf before the s/c instead of close to the TB where it should be, and I've heard all sorts of bad things about premature s/c failure (although I've also heard it's a somewhat easy fix, just don't remember what it is). I'd definitely invest in some tuning software or go to someone to tune it if I were you, maybe some bigger fuel injectors too if the rsm kit doesn't already come with them. Also as far as tuning goes, I'd invest in a wideband O2 sensor (keep in mind it wont replace the stock narrow band O2, it's just meant to compliment it), that way you can precisely tune your fuel trims and such.
      • Azrael
        Accelerating uphill in OD
        • Apr 2005
        • 763
        He won't have to worry about RSM's tuning as his car is an OBDI system and the RSM kit was made for OBDII cars.
        The premature failures were from the use of rubber-walled bearings and the key for the pulley was made of low-grade steel.
        1995 Grand Am SE
        • jackflat0021
          • Feb 2007
          • 26
          yea my car is OBDI the engine and tranny are stock i would say thank you for the mod info but it was kinda confusing
          • angrysk8r
            • Apr 2007
            • 15
            true, didn't even think about that
            • jackflat0021
              • Feb 2007
              • 26
              i been lookin into converting from OBDI to OBDII but i have no idea where to start
                Look into changing over to the TGP 3.1 code with a 2-Bar MAP. There are lots of people running boost on 3.1's using that setup.
                OBD1 > OBD2
                • MY91GT(Z)
                  • Sep 2006
                  • 387
                  whats rsm website and how much is this kit
                  • angrysk8r
                    • Apr 2007
                    • 15
                    parts for your car still sells it i think
                    Shop performance car parts online at PFYC.com! Explore aftermarket & OEM parts like camshafts, spoilers, turbos & more — shop now!
                    it's pretty pricey though at $4400, if I were you I'd go the turbo route instead, you could make a setup better than that for half the price.
                    • MY91GT(Z)
                      • Sep 2006
                      • 387
                      damn i didnt think it was that much they ought to consider lowerin the price, if they want to sell more than they have
                      • jackflat0021
                        • Feb 2007
                        • 26
                        thanks superdave
                        im lookin the one from
                        they have it listed for a malibu
                        yeah i wanted to create a new Grand national but all the shops round here suck and nobody wants to teach me so i been tryin to teach myself and doin bad at it
                        • silvergtjrad
                          uber slow grand am
                          • Feb 2007
                          • 302
                          Originally posted by jackflat0021 View Post
                          thanks superdave
                          The "new" grand national already exists. Its called a buick regal gs.
                          • jackflat0021
                            • Feb 2007
                            • 26
                            well thanks for condescending to me but im talkin bout turbo buicks coupes
                            but superdave where would i get the tools and software to give my car this tune
                            • MY91GT(Z)
                              • Sep 2006
                              • 387
                              moates.com for obd 1 and dhp(digitalhorsepower.com) for obd 2 tuning
